| Software | RG-MAP852-SF-M |
     | Applicable software version | RGOS11.9(6)W1B9 or later |
     | WLAN |
     | Maximum number of associated STAs | 1,024 (up to 512 STAs per radio) |
     | Maximum number of BSSIDs | 16 (up to 8 BSSIDs per radio) |
     | WLAN service | Maximum number of WLAN IDs: 8 Maximum number of users per WLAN: 1,024 |
     | STA management | SSID hiding Band steering Intelligent load balancing based on client count, traffic, or radio frequency Enabling or disabling the radio as scheduled Intelligent STA identification technology Rate set settings Remote Intelligent Perception Technology (RIPT) Parameter adjustment for enhanced user experience: client RSSI threshold, client idle timeout, client average rate threshold, transmit power of beacon frames and probe responses |
     | STA limiting | SSID-based STA limiting Radio-based STA limiting |
     | Bandwidth limiting | WLAN QoS rate limiting, fair scheduling, and Wi-Fi Multimedia (WMM) |
     | CAPWAP | IPv4/IPv6 CAPWAP Layer 2 and Layer 3 topology between an AP and an AC An AP can automatically discover the accessible AC. An AP can be automatically upgraded through the AC. An AP can automatically download the configuration file from the AC. CAPWAP through NAT |
     | Data forwarding | Centralized and local forwarding |
     | Wireless roaming | Layer 2 and Layer 3 roaming |
     | Wireless locating | MU and TAG device locating |
     | Application management | Application identification |
     | Security and Authentication |
     | Authentication and encryption | Remote Authentication Dial-In User Service (RADIUS) PSK and web authentication QR code-based guest authentication, SMS authentication, and MAC address bypass (MAB) authentication Data encryption: WEP (64/128 bits), WPA-Personal, WPA-Enterprise, WPA2-Personal (PSK, TKIP, CCMP), WPA2-Enterprise, WPA3-Personal (SAE, WPA2/WPA3 transition mode), WPA3-Enterprise (CCMP) |
     | Data frame filtering | Allowlist, static blocklist, and dynamic blocklist |
     | WIDS | Wireless Intrusion Detection System(WIDS) User isolation Rogue AP detection and containment |
     | ACL | IP standard ACL, MAC extended ACL, IP extended ACL, and expert-level ACL IPv6 ACL Time range-based ACL ACL based on a Layer 2 interface ACL based on a Layer 3 interface Ingress ACL based on a wireless interface Dynamic ACL assignment based on 802.1X authentication (used with the AC) |
     | CPP | CPU Protect Policy (CPP) |
     | NFPP | Network Foundation Protection Policy (NFPP) |
     | Routing and Switching |
     | MAC | Static and filtered MAC addresses MAC address table size: 2048 Maximum number of static MAC addresses: 2,048 Maximum number of filtered MAC addresses: 2,048 |
     | Ethernet | Jumbo frame length: 1,518 bytes Full-duplex and half-duplex modes of interfaces IEEE802.1p and IEEE802.1Q Optical module information display, alarms about faults, and diagnosis parameter measurement (QSFP+/SFP+/SFP) |
     | VLAN | Interface-based VLAN assignment, VLAN group Maximum number of SVIs: 100 Maximum number of VLANs: 4,094 VLAN ID range: 1 to 4,094 |
     | ARP | ARP entry aging, gratuitous ARP learning, and proxy ARP Maximum number of ARP entries: 1024 ARP check |
     | IPv4 services | IPv4 ping and IPv4 traceroute DNS client DHCP server, DHCP client, and DHCP relay DHCPv4 snooping IPv4 source guard |
     | IPv6 services | Static and dynamic IPv6 addresses Neighbor Discovery (ND) IPv6 ping and IPv6 traceroute IPv6 transparent transmission ICMPv6 IPv6 DHCP client |
     | IP routing | IPv4/IPv6 static routing Maximum number of static IPv4 routes: 1,024 Maximum number of static IPv6 routes: 1,000 Static black hole routing |
     | Multicast | Multicast-to-unicast conversion |
     | VPN | PPPoE client IPsec VPN |
     | Network Management and Monitoring |
     | Network management | NTP server and NTP client SNTP client SNMPv1/v2c/v3 Fault detection and alarm Information statistics and logging |
     | Network management platform | Web management (Eweb) |
     | User access management | Telnet and TFTP client |
     | Switchover among Fat, Fit, and cloud modes | When the AP works in Fit mode, it can be switched to Fat mode through an AC. When the AP works in Fat mode, it can be switched to Fit mode through the console port or Telnet mode. When the AP works in cloud mode, it can be managed through WIS Cloud. |
