RG-MUX-EXT Switches - 1
RG-MUX-EXT Switches - 2
RG-MUX-EXT Switches - 3
RG-MUX-EXT Switches - 4
RG-MUX-EXT Switches - 5
RG-MUX-EXT Switches - 6
RG-MUX-EXT Transparent Distribution Expansion Module Optical Splitter
Applicable in VSU networking scenarios, provides two uplink splitting ports, and works together with RG-MUX-8LC/LC-H.
  • Building-side transparent distribution expansion module offering two uplink splitting ports, suitable for VSU networking
  • Splitter and transparent distribution device achieve dual all-optical uplinks, improving link reliability between core and building sides
Funktionen
Transparent distribution expansion module on the building side. The optical splitter works together with RG-MUX-8LC/LC-H and provides short fibers and two uplink splitting ports, making it suitable for VSU networking scenarios.
Spezifikationen
Product Specifications
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
1 x multiplexing port
Wavelength range
1271 nm to 1571 nm (CWDM)
Channel spacing
20 nm
20 nm
20 nm
Channel bandwidth
±6 nm
±6 nm
±6 nm
Insertion loss
< 3.7 dB
< 2.6 dB
< 4.2 dB
Return loss
> 45 dB
> 45 dB
> 45 dB
Polarization loss
< 0.3 dB
< 0.3 dB
< 0.3 dB
Adjacent channel isolation
> 25 dB
> 25 dB
> 35 dB
> 35 dB
LC/UPC
LC/UPC
LC/UPC
0.25 kg (0.55 lbs)
0.25 kg (0.55 lbs)
0.15 kg (0.33 lbs)
4.53 kg (9.99 lbs)
Communication standard
GR-1221-Core and GR-1209-Core
RG-MUX-BOX
0.9 kg (1.98 lbs)
11.5 kg (25.35 lbs)
Ressourcen
Auftragsinformationen
RG-MUX-8LC/LC
RG-MUX-8LC/LC-H
RG-MUX-EXT
RG-MUX-BOX
Häufig gestellte Fragen
