MINI-GBIC-SX-MM850 Switches - 1
MINI-GBIC-SX-MM850 Switches - 2
MINI-GBIC-SX-MM850 Switches - 3
MINI-GBIC-SX-MM850 Switches - 4
MINI-GBIC-SX-MM850 Switches - 5
Funktionen
MINI-GBIC-SX-MM850 Module
Spezifikationen
MINI-GBIC-GT
1.25 Gbps
1000base-X to 1000base-T
RJ45
Cat 5e/6/6a
550 m (1,804.46 ft.)
80 km (262,467.19 ft.)
100 m (328.08 ft.)
No
≤ 1.5 W
Wavelength (nm)
850
1310
1310
1550
–3 dBm
5 dBm
–9.5 dBm
–11 dBm
–5 dBm
Min. extinction ratio
≥ 9 dB
< –17 dBm
< –19 dBm
< –23 dBm
< –27 dBm
–3 dBm
–3 dBm
–3 dBm
35 g (0.08 lbs.)
1.25 Gbps
FP
FP
20 km (65,616.80 ft.)
3 km (9,842.52 ft.)
≤ 1.5 W
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
1310 nm TX
1550 nm RX
1550 nm TX
1310 nm RX
–3 dBm
–5 dBm
–9 dBm
≥ 9 dB
< –23 dBm
< –20 dBm
< –22 dBm
–3 dBm
5% RH to 95% RH
5% RH to 95% RH
35 g (0.08 lbs.)
Ressourcen
Auftragsinformationen
