Hardware Specifications |
RG-S5310-24GT4XS-E |
RG-S5310-24GT4XS-P-E |
RG-S5310-48GT4XS-E |
RG-S5310-48GT4XS-P-E |
Interface Specifications |
Fixed Ports |
24x10/100/1000 BASE-T ports 4 x 1G/10G SFP+ ports |
24x 10/100/1000 BASE-T ports 4x 1G/10G SFP+ ports Supports PoE Standards IEEE 802.3af, 802.3at |
48 x 10/100/1000 BASE-T ports 4 x 1G/10G SFP+ ports |
48 x 10/100/1000 BASE-T ports 4x 1G/10G SFP+ ports Supports PoE Standards IEEE 802.3af, 802.3at |
Power Supplies |
1+1 redundancy of power modules |
1+1 redundancy of power modules Up to 720 W of PoE+ |
1+1 redundancy of power modules Up to 1,440 W of PoE+ |
Management Port |
1 MGMT port, 1 console port, and 1 USB port, compliant with USB2.0 standard |
System Specifications |
System Switching Capacity |
3.36Tbps |
3.36Tbps |
4.32Tbps4 |
4.32Tbps4 |
Packet Forwarding Rate |
126Mpps |
126Mpps |
166Mpps |
166Mpps |
No. of VSU Members |
4 |
4 |
4 |
4 |
MAC Address |
128000 | |||||
ARP Table |
4k,16k(authorized) |
Routing Table Size (IPv4) |
8K,12k(authorized) |
Routing Table Size (IPv6) |
4k |
4k |
4k |
4k |
ACL Entries |
In: 3500 Out:1500 |
In: 3500 Out:1500 |
In: 3500 Out:1500 |
In: 3500 Out:1500 |
CPU and Storage |
CPU |
Dual-Core CPU, 1.2GHz |
Flash Memory |
2GB |
Dimensions and Weight |
Dimensions (W × D × H) |
442 mm × 420 mm × 43.6 mm,1 RU |
Weight |
4.2KG(9.26 lbs) |
4.3KG (9.48 lbs) |
4.3KG (9.48 lbs) |
4.6KG (10.14 lbs) |
Power and Consumption |
Rated Voltage |
S5310-24GT4XS-E、RG-S5310-48GT4XS-E ,AC input: Rated voltage range: 100 V to 240 V Frequency: 50/60 Hz RG-S5310-24GT4XS-P-E、RG-S5310-48GT4XS-P-E,AC input: Rated voltage range: 200 V to 240 V |
Maximum Voltage |
RG-S5310-24GT4XS-E、RG-S5310-48GT4XS-E ,AC input: Maximum voltage range: 90 V to 264 V Frequency: 50/60 Hz RG-S5310-24GT4XS-P-E、RG-S5310-48GT4XS-P-E, AC input: Maximum voltage range: 176 V to 264 V |
Maximum Power Consumption |
≤40W |
<85W(Non POE) <810W (PoE full load) |
≤55W |
<75W(Non POE) <1570W (PoE full load) |
Environment and Reliability |
Temperature |
Operating temperature: 0℃~45℃ Storage temperature: -40℃ to 70℃ |
Relative Humidity |
Operating humidity: 10% to 90%RH Storage humidity: 5% to 95%RH |
Lightning Protection |
10KV (Service Interface) 4KV (MGMT Interface) |
Fan Monitoring |
Fan speed regulating and alarm function |
RG-S5310-E Series |
Feature |
Description |
Ethernet Switching |
IEEE 802.1Q (supporting 4K VLANs) |
Maximum number of VLANs that can be created: 4,094 |
Voice VLAN |
Super VLAN and private VLAN |
MAC address-based, port-based, protocol-based, and IP subnet-based VLAN assignment |
GVRP |
Basic QinQ and selective QinQ |
STP (IEEE 802.1.d), RSTP (IEEE 802.1w), and MSTP (IEEE 802.1s) |
Auto errdisable recovery BPDU filter BPDU guard Port fast Root guard |
ERPS (G.8032) |
LLDP/LLDP-MED, LLDP IPv6, and LLDP-POE |
IP Service |
DHCP client, DHCP relay, DHCP server, and DHCP snooping |
DHCPv6 client, DHCPv6 relay, DHCPv6 server, and DHCPv6 snooping |
DNS client, DNS proxy, and DNSv6 client |
MAC address filtering Setting the MAC address aging time |
Neighbor Discovery (ND), ND proxy, and ND snooping |
GRE tunnel |
IP Routing |
IPv4 and IPv6 static routing |
RIP and RIPng |
OSPFv2, OSPFv3, and GR |
IS-ISv4 and IS-ISv6 |
BGP4 and BGP4+ |
IPv4/IPv6 VRF |
IPv4/IPv6 PBR |
Multicast |
IGMPv1/v2/v3 |
IGMPv1/v2 snooping |
IGMP fast leave |
PIM-DM, PIM-SM, PIM-SSM, PIM SMv6, and PIM-SSMv6 |
MSDP for inter-domain multicast |
MLDv1/v2 and MLD proxy |
MLDv1/v2 snooping |
PIM-SMv6 |
Multicast source IP address check Multicast source port check |
Multicast querier |
ACL and QoS |
Standard IP ACLs (hardware ACLs based on IP addresses) |
Extended IP ACLs (hardware ACLs based on IP addresses or TCP/UDP port numbers) |
Extended MAC ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type) |
Expert-level ACLs (hardware ACLs based on flexible combinations of the VLAN ID, Ethernet type, MAC address, IP address, TCP/UDP port number, protocol type, and time range) |
Time based ACLS, ACL 80, and IPv6 ACL |
Global ACLs |
ACL redirection |
Port traffic identification |
Port traffic rate limiting |
802.1p/DSCP/ToS traffic classification |
Congestion management: SP, WRR, DRR, WFQ, SP+WFQ, SP+WRR, SP+DRR, and SP+WFQ |
Congestion avoidance: tail drop, RED, and WRED |
Eight priority queues per port |
Rate limiting in each queue |
Security |
Multiple AAA modes |
RADIUS authentication and authorization |
RADIUS and TACACS+ |
IEEE802.1X authentication, MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication |
Web authentication |
Hypertext Transfer Protocol Secure (HTTPS) |
SSHv1 and SSHv2 |
Global IP-MAC binding |
ICMPv6 |
Port security |
IP source guard |
SAVI |
ARP spoofing prevention |
CPP and NFPP |
Multiple attack defense functions |
3-tuple binding (IP address, MAC address, and port) 3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses Port- and MAC address-based 802.1x authentication MAB authentication Portal authentication and Portal 2.0 authentication ARP check DAI ARP packet rate limiting Gateway ARP spoofing prevention Broadcast storm suppression Hierarchical management of administrators and password protection BPDU guard Port protection |
Reliability |
REUP |
RLDP |
RLDP, Layer 2 link connectivity detection, and unidirectional link detection |
DLDP |
IPv4 VRRP v2/v3, IPv6 VRRP, and super-VLAN for VRRP |
BFD, RAS, NSR, VRRR, VRRP+, and SDN loop detection |
Basic LACP Inter-VSU AP |
Link monitoring, fault notification, and remote loopback based on 802.3ah (EFM) |
Hot swapping of power modules |
Device virtualization |
VSU Local and remote stacking Inter-chassis link binding in a stack Virtualization through standard service interfaces |
NMS and maintenance |
RSPAN and ERSPAN |
sFlow |
NTP client, NTP server, NTPv6 client, and NTPv6 server |
SNTP |
CLI (Telnet/Console) |
FTP client, FTP server, FTPv6 client, and FTPv6 server |
TFTP client, TFTP server, TFTPv6 client, and TFTPv6 server |
FTP and TFTP |
SNMP v1/v2/c3 |
Web |
Syslog/Debug |
RMON (1, 2, 3, 9) Various types of RMON groups, including event groups, alarm groups, history groups, and statistics groups, as well as private alarm extension groups RMON used to implement Ethernet statistics, historical statistics, and alarm functions |
NETCONF |
MACC |
CWMP |
gRPC |
OpenFlow Special 1.3 Flow table analysis defined by all protocols Transmission of specified packets to the controller Configuring the controller's IP address and port Notifying port status changes to the controller |
RNS, configuration rollback, and 802.3ah |
1:1 mirroring N:1 mirroring 1:N mirroring Flow-based local and remote mirroring |
VXLAN |
VXLAN (authorized) |
PoE |
RG-S5310-24GT4XS-P-E and RG-S5310-48GTXS-P-E: IEEE 802.3af and 802.3at power supply standards Automatic and energy-saving power supply management modes Uninterrupted power supply in hot start mode Scheduled power-on or power-off of PoE ports based on the time policy Port priority |
RG-S5310-E Series |
Organization |
Standards and Protocol |
IETF |
RFC 1058 Routing Information Protocol (RIP) RFC 1157 A Simple Network Management Protocol (SNMP) RFC 1305 Network Time Protocol Version 3 (NTP) RFC 1349 Internet Protocol (IP) RFC 1350 TFTP Protocol (revision 2) RFC 1519 CIDR RFC 1583 OSPF Version 2 RFC 1591 Domain Name System Structure and Delegation RFC 1643 Ethernet Interface MIB RFC 1757 Remote Network Monitoring (RMON) RFC 1812 Requirements for IP Version 4 Router RFC 1901 Introduction to Community-based SNMPv2 RFC 1902-1907 SNMP v2 RFC 1918 Address Allocation for Private Internet RFC 1981 Path MTU Discovery for IP version 6 RFC 1997 BGP Communities Attribute RFC 2131 Dynamic Host Configuration Protocol (DHCP) RFC 2132 DHCP Options and BOOTP Vendor Extensions RFC 2236 IGMP RFC 2328 OSPF Version 2 RFC 2385 Protection of BGP Sessions via the TCP MD5 Signature Option RFC 2439 BGP Route Flap Damping RFC 2460 Internet Protocol, Version 6 (IPv6) RFC 2461 Neighbor Discovery for IP Version 6 (IPv6) RFC 2462 IPv6 Stateless Address Auto configuration RFC 2463 Internet Control Message Protocol for IPv6 (ICMPv6) RFC 2545 Use of BGP 4 Multiprotocol Extensions for IPv6 Inter Domain Routing RFC 2571 SNMP Management Frameworks RFC 2711 IPv6 Router Alert Option RFC 2787 Definitions of Managed Objects for the Virtual Router Redundancy Protocol RFC 2863 The Interfaces Group MIB RFC 2865 Remote Authentication Dial In User Service (RADIUS) RFC 2918 Route Refresh Capability for BGP 4 RFC 2925 Definitions of Managed Objects for Remote Ping, Traceroute, and Lookup Operations (Ping only) RFC 2934 Protocol Independent Multicast MIB for IPv4 RFC 3046 DHCP Option82 RFC 3065 Autonomous System Confederation for BGP RFC 3101 OSPF Not so stubby area option RFC 3137 OSPF Stub Router Advertisement sFlow RFC 3417 (SNMP Transport Mappings) RFC 3418 Management Information Base (MIB) for the Simple Network Management Protocol (SNMP) RFC 3509 Alternative Implementations of OSPF Area Border Routers RFC 3513 IP Version 6 Addressing Architecture RFC 3575 IANA Considerations for RADIUS RFC 3579 RADIUS Support For EAP RFC 3623 Graceful OSPF Restart RFC 3768 VRRP RFC 3810 Multicast Listener Discovery Version 2 (MLDv2) for IPv6 RFC 3973 PIM Dense Mode RFC 4022 MIB for TCP RFC 4271 A Border Gateway Protocol 4 (BGP 4) RFC 4273 Definitions of Managed Objects for BGP 4 RFC 4360 BGP Extended Communities Attribute RFC 4456 BGP Route Reflection: An Alternative to Full Mesh Internal BGP (IBGP) RFC 4486 Subcodes for BGP Cease Notification Message RFC 4552 Authentication/Confidentiality for OSPFv3 RFC 4724 Graceful Restart Mechanism for BGP RFC 4750 OSPFv2 MIB partial support no SetMIB RFC 4760 Multiprotocol Extensions for BGP 4 RFC 4940 IANA Considerations for OSPF RFC 5065 Autonomous System Confederation for BGP RFC 5187 OSPFv3 Graceful Restart RFC 5340 OSPFv3 for IPv6 RFC 5492 Capabilities Advertisement with BGP 4 RFC 6620 FCFS SAVI RFC 768 User Datagram Protocol (UDP) RFC 783 TFTP Protocol (revision 2) RFC 792 Internet Control Message Protocol (ICMP) RFC 793 Transmission Control Protocol (TCP) RFC 813 Window and Acknowledgement Strategy in TCP RFC 815 IP datagram reassembly algorithms RFC 826 Ethernet Address Resolution Protocol (ARP) RFC 854 Telnet Protocol RFC 959 File Transfer Protocol (FTP) |
IEEE |
IEEE 802.2 Logical Link Control IEEE 802.1ab Link Layer Discovery Protocol IEEE 802.1ad Provider Bridges IEEE 802.1ax/IEEE802.3ad Link Aggregation IEEE 802.1D Media Access Control (MAC) Bridges IEEE 802.1D Spanning Tree Protocol IEEE 802.1Q Virtual Bridged Local Area Networks (VLAN) IEEE 802.1s Multiple Spanning Tree Protocol IEEE 802.1w Rapid Spanning Tree Protocol IEEE 802.3ad Link Aggregation Control Protocol (LACP) IEEE Std 802.3x Full Duplex and flow control IEEE 802.3bt Power over Ethernet (supported by PoE-capable models) |
Electromagnetic Compatibility (EMC) Standards: ✓CISPR 22/EN 55032 (Conducted and Radiated Emissions) ✓EN 55035 (Immunity) ✓IEC/EN 61000-4-2 or ANSI/ESD S20.20 (Electrostatic Discharge - ESD) ✓IEC/EN 61000-4-3 (Radio Frequency Electromagnetic Field) ✓IEC/EN 61000-4-4 (Electrical Fast Transient -EFT) ✓IEC/EN 61000-4-5 (Surge Immunity) ✓IEC/EN 61000-4-6 (Radio Frequency Common Mode) ✓IEC/EN 61000-4-11 (Voltage Dips and Interruptions) ✓IEC/EN 61000-3-2(Voltage Dips and Interruptions) ✓IEC/EN 61000-3-2 (Voltage Dips and Interruptions) • Safety Standards: ✓IEC 60950/EN 62368 ✓IEC 60068 ✓RoHS or WEEE (Environmental) |
Model |
Description |
RG-S5310--24GT4XS-E |
24 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports |
24 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE and the maximum PoE output power of 740 W. |
48 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports |
48 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE and the maximum PoE output power of 1440 W |
RG-PA70IB |
70 W AC power module |
RG-PA150IB-F |
150 W AC power module |
RG-PA600I-P-F |
600 W AC power module, PoE power module |
RG-PA1000I-P-F |
1,000 W AC power module, PoE power module |
RG-VXLAN-MPLS-ENTRY-LIC |
S5310E series, software license for VXLAN, MPLS, routing table, and ARP table |
Mini-GBIC-GT |
1000BASE-GT mini GBIC module |
Mini-GBIC-SX-MM850 |
Single-port 1000BASE-SX mini GBIC module (LC) |
Mini-GBIC-LX-SM1310 |
Single-port 1000BASE-LX mini GBIC module (LC) |
Mini-GBIC-LH40-SM1310 |
Single-port 1000BASE-LH mini GBIC module (LC), supporting a transmission distance of 40 km |
Mini-GBIC-ZX100-SM1550 |
1000BASE-ZX mini GBIC module, supporting a transmission distance of 100 km |
XG-SFP-SR-MM850 |
10G LC interface module (62.5/125 μm: 33 m; 50/125 μm: 66 m; 300-meter transmission at modal bandwidth of 2000 MHz•km), applicable to SFP+ ports |
XG-SFP-LR-SM1310 |
10G LC interface module (1310 nm), 10 km, applicable to SFP+ ports |
XG-SFP-ER-SM1550 |
10G LC interface module (1550 nm), 40 km, applicable to SFP+ ports |
