RG-SF2920U-4GT1MS-P Thiết bị chuyển mạch - 1
RG-SF2920U-4GT1MS-P Thiết bị chuyển mạch - 2
RG-SF2920U-4GT1MS-P Thiết bị chuyển mạch - 3
RG-SF2920U-4GT1MS-P Thiết bị chuyển mạch - 4
RG-SF2920U-4GT1MS-P Thiết bị chuyển mạch - 5
RG-SF2920U-4GT1MS-P Thiết bị chuyển mạch - 6
RG-SF2920U-4GT1MS-P 4-Port GE All-Optical PoE Switch, 1 x 2.5G Uplink Optical Port (Backward Compatible)
  • Various port combinations, surge protection greater than 8 kV, 4 x 10/100/1000BASE-T ports, PoE/PoE+ supported, and 1 x 1GE/2.5GE SFP port for uplink
  • Reliability enhancement, independent optical transceiver design, and more stable data forwarding
Thông số chính
All-Optical Ethernet Switch RG-SF2920U-4GT1MS-P
This switch provides 4 x 10/100/1000BASE-T ports, PoE/PoE+ supported, 1 x 1GE/2.5GE SFP uplink port, rich interfaces, supporting full service expansion.
and No Security Concern
Flexible Installation
Heat Dissipation Design
Quietness
Optical Link O&M
Thông số kỹ thuật
Port Specifications
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
8 x 10/100/1000BASE-T ports
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2MG2XS
RG-SF2920-16GT2SFP
2 x 1G/2.5GBASE-T ports
2 x 1GE/10GE SFP+ ports
16 x 10/100/1000BASE-T ports
2 x 1GE SFP ports
RG-SF2920-16GT2SFP-P
RG-SF2920-8GT2MG2XS-P
RG-SF2920-16GT2MG2XS-P
2 x 1GE SFP ports
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
16 Mpps
9.7 Mpps
16 Mpps
System switching capacity *2
21 Gbps
13 Gbps
21 Gbps
1 MB
Ingress: 1,500
Egress: 500
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
49.1 Mpps
61 Mpps
26.8 Mpps
66 Gbps
82 Gbps
256 MB
512 MB DDR3
1.5 MB
500
500
Ingress: 1,500
Egress: 500
26.8 Mpps
56.5 Mpps
68.44 Mpps
76 Gbps
92 Gbps
256 MB
512 MB DDR3
1.5 MB
500
500
Ingress: 1,500
Egress: 500
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
1.18 kg (2.6 lbs)
1.43 kg (3.15 lbs)
1.74 kg (3.84 lbs)
1.98 kg (4.37 lbs)
2.23 kg (4.92 lbs)
2.54 kg (5.60 lbs)
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
1.97 kg (4.34 lbs)
2.04 kg (4.5 lbs)
1.98 kg (4.37 lbs)
2.75 kg (6.06 lbs)
2.81 kg (6.19 lbs)
2.75 kg (6.06 lbs)
2.34 kg (5.16 lbs)
2.33 kg (5.14 lbs)
2.33 kg (5.14 lbs)
3.11 kg (6.86 lbs)
3.12 kg (6.88 lbs)
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
1 x fixed power module
Fixed power supply: 25 W
Fixed power supply: 70 W
Fixed power supply: 150 W
The maximum power is 45 W
8.5 W
10 W (without PoE load)
55 W (full PoE load)
16.5 W (without PoE load)
141.5 W (full PoE load)
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
25 W (without PoE load)
150 W (full PoE load)
RG-SF2920 Series
Operating temperature:
Air discharge: 15 kV
Contact discharge: 8 kV
Service port: 8 kV
RG-SF2920 Series
RG-SF2920U
RSTP (IEEE 802.1w)
SNTP
MQTT
Syslog/Debugging
RG-SF2920
MAC VLAN
Basic QinQ and flexible QinQ
Static blackhole routing
ACL80 and IPv6 ACLs
SSHv1.5 and SSHv2.0
Portal authentication
Unknown unicast suppression
Load balancing
LACP dynamic aggregation
Cross-VSU aggregate interface
IPv4 VRRP v2/v3, IPv6 VRRPv3
GR for OSPF
SPAN, RSPAN and ERSPAN
Flow- and VLAN-based SPAN
● Port priority
Tài nguyên
Thông tin đặt hàng
RG-SF2920U-8GT1MS
RG-SF2920U-4GT1MS-P
RG-SF2920U-8GT1MS-P
RG-SF2920-8GT2MG2XS
RG-SF2920-16GT2SFP
CWDM
