RG-CS85-48SFP4XS-D 48-Port GE All-Optical Layer 3 Enterprise-Class Core or Aggregation Switch, 4 × 10G Uplink Ports
  • Rich port types, 48 x SFP ports, and 4 × 10G optical ports for uplink
Aggregation switch for small and medium-sized campus networks, with four 10G uplink optical ports for high-speed data transmission; 48 x 1000 Mbps optical ports, providing high-speed network experience for long-distance services. Core switch for small and medium-sized enterprise networks, with high scalability, efficiency, and manageability, and device-level and link-level reliabilities for stable connectivity.
Hot-Swappable Power Modules
Abundant Multicast Protocols
Flexible management modes
RG-CS85-24GT8XS-D
RG-CS85-24SFP/8GT8XS-D
RG-CS85-48GT4XS-D
RG-CS85-48GT4XS-HPD
RG-CS85-48SFP4XS-D
Interface Specifications
Fixed port
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports
24 x 1000 Mbps SFP ports (ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, PoE/PoE+ supported, 4 x 1GE/10GE SFP+ ports
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports
Fan module
3 fixed fans
3 fixed fans
3 fixed fans
2 modular fans
3 modular fans
2 replaceable hot-swappable power supply slots
1 x console, 1 x MGMT, 1 x USB3.0
Expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
One expansion slot
512 Mpps
512 Mpps
488 Mpps
488 Mpps
488 Mpps
688 Gbps
688 Gbps
656 Gbps
656 Gbps
656 Gbps
14,000
14,000
14,000
14,000
14,000
Ingress: 7,000
Egress:1,500
440 x 340 x 44 mm (17.32 x 13.39 x 1.73 in), 1 RU
442 x 420 x 43.6 mm (17.40 x 16.54 x 1.72 in), 1 RU
4.4 kg (9.70 lbs)
4.3 kg (9.48 lbs)
4.5 kg (9.92 lbs)
5.5 kg (12.12 lbs)
5.3 kg (11.68 lbs)
CPU and Storage
Dual-core CPU, 1.2 GHz
4 GB
4 GB
4 GB
4 GB
4 GB
SDRAM
Data packet buffer
Power and Consumption
<60 W (excluding expansion modules)
<85 W (including expansion modules)
<77 W (excluding expansion modules)
<102 W (including expansion modules)
<70 W (excluding expansion modules)
<95 W (including expansion modules)
<110 W (non-PoE)
<1,590 W (PoE full load)
<150 W
RG-PA150IB-F: 150 W
RG-PA150IB-F: 150 W
RG-PA150IB-F: 150 W
176 V AC to 290 V AC, 1000 W
90 V AC to 176 V AC, 930 W (PoE: 740 W)
Rated input voltage
AC: 100 V to 240 V
HVDC: 240 V
LVDC: 48 V to 60 V
AC:
200 V to 240 V
DC: -48 V to -60 V
AC: 100 V to 240 V
DC: -48 V to -60 V
Maximum input voltage
AC: 90 V to 264 V
HVDC: 192 V to 288 V
LVDC: 36 V to 75 V
AC: 176 V to 264 V
DC: -38 V to -75 V
AC: 90 V to 264 V
DC: -36 V to -75 V
≥ 1,051,000 hours
≥ 823,000 hours
≥ 963,000 hours
≥ 832,000 hours
≥ 788,000 hours
Primary Airflow
Front-to-rear airflow
0°C to 45°C (32°F to 113°F)
-40°C to +70°C (-40°F to +158°F)
5% to 95% RH (non-condensing)
Operating noise
45°C: 56.2 dB
45°C: 57.1 dB
45°C: 57.9 dB
27°C: 50 dB
45°C: 65 dB
27°C: 53 dB
45°C: 68 dB
Interface surge protection
Power port: 6 kV/6 kV
Telecom port: 10 kV (MGMT port: 4 kV)
RG-CS85 Series
Super VLAN, Private VLAN
Flexible QinQ
RADIUS and TACAS+
RG-CS85-24GT8XS-D
24 x 10/100/1000 Mbps electrical ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
24 x 10/100/1000 Mbps SFP ports (Ports 1-16 are 100/1000 Mbps SFP ports), 8 x 10/100/1000 Mbps combo ports with auto-negotiation, 8 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48GT4XS-D
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x built-in fixed fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
RG-CS85-48GT4XS-HPD
48 x 10/100/1000 Mbps electrical ports with auto-negotiation, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 2 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA600I-P-F/RG-PA1000I-P-F module.)
RG-CS85-48SFP4XS-D
48 x 1000 Mbps SFP ports, 4 x 1GE/10GE SFP+ ports, 1 x expansion slot, 3 x modular fans, 2 x power supply module slots (Purchase at least one RG-PA150IB-F module.)
CM85-4XS2CQ
Expansion module, 4 x 10GE SFP+ ports and 2 x 100GE QSFP28 ports
150 W AC power supply module
600 W PoE AC power supply module
1000 W PoE AC power supply module
1000BASE-GT mini GBIC module
Single-port 1000BASE-SX mini GBIC module (LC interface)
Single-port 1000BASE-LX mini GBIC module (LC interface)
Single-port 1000BASE-LH mini GBIC module (LC interface), supporting a transmission distance of 40 km (24.85 miles)
MINI-GBIC-ZX50-SM1550
Single-port 1000BASE-ZX mini GBIC module (LC interface), supporting a transmission distance of 50 km (24.85 miles)
Single-port 1000BASE-ZX mini GBIC module (LC interface), supporting a transmission distance of 80 km (24.85 miles)
MINI-GBIC-ZX100-SM1550
1000BASE-ZX mini GBIC module, supporting a transmission distance of 100 km (62.14 miles)
10GE LC module (62.5/125μm: 33 m (108.27 ft); 50/125μm: 66 m (216.54 ft); transmit for 300 m (984.25 ft) when modal bandwidth is 2000Mhz *km), applicable to SFP+ ports
10GE SFP+ fiber-optic cable, 1 m (3.28 ft), including one cable and two interface modules
10GE SFP+ fiber-optic cable, 3 m (3.28 ft), including one cable and two interface modules
10GE SFP+ fiber-optic cable, 5 m (3.28 ft), including one cable and two interface modules
Technical Support
Technical Support
Get in Touch
Get in Touch
