RG-RSR77-XA-08 10 RU Multiservice Core Modular Router
The RG-RSR77-XA-08 series is mainly used as the core or aggregation node on a WAN of the government, finance, carrier, education, or large- and medium-sized enterprise network.
  • A modular design with various expansion card interfaces, supporting rates ranging from 2 Mbps to 100 Gbps
  • Support for Segment Routing over IPv6 (SRv6), simplifying protocol configuration and facilitating quick service rollout
  • Redundancy for critical components, ensuring uninterrupted services and improving overall reliability
  • Y-shaped airflow design, improving cooling efficiency and lowering energy consumption
Multiservice Core Router RG-RSR77-XA-08
Appearance
Line cards include main cards and subcards. The subcards support multiple types of ports, including E1, POS, GE, 10GE, and 100GE ports. You can install subcards as needed to meet different networking requirements.
SRv6
1:1 Routing Engine Redundancy
If the active routing engine fails, data is switched to the standby routing engine within seconds.
3+1 Switching Fabric Module Redundancy
The router supports redundant and hot-swappable switch fabric modules, ensuring zero packet loss during failover scenarios.
RG-RSR77-XA-03
RG-RSR77-XA-08
Interface Specifications
4 (N+N redundancy)
1 x console port, 1 x MGMT port, and 1 x USB port
Supervisor module slot
Switch fabric module
Service module slot
3
Line card slot
12
32
1.2 Tbps
3.2 Tbps
40,000
40,000
2,000,000
 2,000,000
8,000
8,000
1,500,000
 1,500,000
32,000
32,000
442 mm x 560 mm x 220 mm (17.40 in. x 22.05 in. x 8.66 in.), 5 RU
442 mm x 560 mm x 442 mm (17.40 in. x 22.05 in. x 17.40 in.), 10 RU
Weight (empty chassis and fan modules)
12.5 kg (27.56 lbs)
43.55 kg (96.01 lbs)
Power and Consumption
Maximum power
consumption
60 W
RG-PA460-RI: 90 V AC to 290 V AC, 460 W
RG-PA1600I:
90 V AC to 176 V AC, 1200 W
176 V to 290 V AC, 1600 W
RG-PD600I: 600 W
Rated input voltage
● AC: 100 V to 240 V AC, 50 Hz to 60 Hz
● AC: 100 V to 240 V AC, 50Hz~60Hz
● DC: –48 V to –60 V DC
Maximum input voltage
● AC: 90 V AC to 290 V AC, 45 Hz to 65 Hz
● AC: 90 V to 290V AC, 47Hz~63Hz
● DC: –38 V to –75 V DC
216,000 hours
342,000 hours
Primary airflow
Fans drawing air for forced convection
0°C to 45°C (32°F to 113°F)
Operating noise
Ambient temperature ≤ 70 dB
Maximum noise < 77 dB
35°C (95°F): 60 dB
50°C (122°F): 75 dB
RG-RSR77-XA Series
FTP, TFTP, FTPv6, and TFTPv6
NTP, SNTP, and NTPv6
NAT
ND
ND and ND snooping
IPv6 GRE tunnel
BGP and BGP4+
Routing policies
BGP4, BGP4+, and MP-BGP
IGMP v1/v2/v3
Static multicast routing
MPLS/SR
Basic MPLS functions
MPLS forwarding
L3VPN
LSP
LDP
IPv6 ACLs
Applying ACLs to interfaces
MPLS QoS
HQoS
Attack defense
Password security
RNFP
FPM
PKI
VPDN
NSR
Hot swapping
SPAN and ERSPAN
IPFIX
Chassis and Supervisor Engines
RG-RSR77-XA-03
RG-RSR77-XA-03 chassis
RG-RSR77-XA-08
RG-RSR77-XA-08 chassis
RSR77-XA-03-CM
RG-RSR77-XA-03 routing switching engine
RSR77-XA-08-CM
RG-RSR77-XA-08 routing engine
RSR77-XA-08-DSF
RSR77-XA-08-DSF II
Power Modules
RG-PA1600I
RG-PA460-RI
RG-PD600I
SIP Carrier Card
RSR77-XA-SIP3
NM/DNM carrier card (four NM modules or two DNM modules supported by each RSR77-XA-SIP3)
RSR77-XA-SIP6
Enhanced carrier card, supporting 2 x DNMX cards
NM Line Card
NM-2XS-KA
NM-4XS-KB
NM-8SFP-G
NM-8GT-G
NM-8E1/CE1
8-port E1/CE1 interface module, requiring adapters and adapter cables
DNM-1CQ-KC
DNMX-20XS
20-port 10GE Ethernet interface module, requiring additional SFP+ modules
DNMX-20SFP
20-port 1GE Ethernet optical interface module, requiring additional SFP modules
DNMX-24GT
24-port 1GE Ethernet electrical interface module
DNMX-4CQ
4-port 100GE/40GE Ethernet interface module, requiring additional SFP+ modules
