Cloud Management Solution
Ideal Choice for Your Managed Services
Business Model
Building Your Managed Services Business to A Variety of Industries
Solution Framework
Solution Highlights
RG-MACC can conduct configuration and manage of all AP,
Switches in one cloud management platform
RG-MACC allows you to have an all-rounded monitoring
on Internet usage, channel usage, traffic usage, RSSI status and etc.
RG-MACC performs as an easy-to-use simulation tool to generate the heat
map according to the imported floor plan with predictions of signal strength,
channel interference and speed.
RG-MACC performs as an easy-to-use simulation tool to generate the heat map according to the imported floor plan with predictions of signal strength, channel interference and speed.
Success Cases
  • City Wifi Project
    for Hefei City of China
  • KTVME’s New Smart
    KTV Era powered by Ruijie
  • Smart City WiFi
    for Baoji City of China
  • “i-Tianjin” China
    Tianjin-City Wifi Case Study
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
