Home> Sản phẩm> Thiết bị không dây> Indoor Access Point Series>
RG-AP730-L
Wi-Fi 5 Wave2 Tri-band Indoor AP
Feature Highlights:
In today’s fast-changing business environment, a reliable and high-performance Wi-Fi infrastructure plays a vital role to ensure the business continuity.
Ruijie AP730-L with unique Wave 2 Tri-band deign is optimized for high density user in SME environment which catering upto 768 users without any issue.
Xem thêm+
Perfect for High Density Wi-Fi
Ruijie AP730-L is specially designed for dense Wi-Fi usage environment like Restaurant, Hotel Reception & Conference Room, Student Lecture Hall, etc. Upto 768 clients per AP supported by AP730-L, max wireless throughput upto 2130Mbps, this is take advantage of IEEE 802.11ac Wave 2 standard (WiFi 5) and unique Tri-band radio design, with single 2.4G radio and dual 5G radio for client access at concurrent, each radio can effectively load balance the traffic without bring additional interference for the environment.
Flexible Hybrid Management
Ruijie SME AP offers the flexibility for SME to choose the mode of management. There are 3 different management modes for selection. For the Ruijie Cloud option, no extra cost or firmware upgrade is required, which saves company expenses and time.
Selection between Ruijie Cloud and Hardware Controller
In some cases, a local on-premise wireless controller is required due to some business requirement. Ruijie SME AP allows the flexibility according to customer preference, the AP can be either managed by Ruijie Cloud or on-premise wireless controller.
Ruijie Cloud and Hardware AC Comparison
Performance Guarantee (Tolly© Certified)
Tolly Group is one of the reputable 3rd party independent performance testing organization. Over 65% of Fortune 100 Companies turn to Tolly Reports to assist in strategic technology decisions.
The Ruijie SME Wireless Access Point performance is further validated in Tolly certified report. We have outperformed other major vendor flagship wireless access point in the real-world performance rating.
On 32 & 100 Client Test:  Ruijie AP result upto 90% LESS video lag time (vs Ubiquiti and Huawei)
Wi-Fi Roaming Test:  Ruijie AP result zero packet loss in Layer 2 & 3 Roaming (vs Ubiquiti)
Long Distance Test:  Ruijie AP result 15% better performance (vs Ubiquiti)
PPSK Enterprise Authentication
For internal staff, it is hassled to maintain the pre-defined PSK and distribute among them. Especially for offboarding employee, potential Wi-Fi PSK leaked out could be harmful to your network.
With Ruijie PPSK, you now can easily provide different Wi-Fi password for each user. It tied to individual end user devices like laptop or smartphone and the same password can’t be used by other. Possibility of Wi-Fi password leak out eliminated completely
Simple and Effective Wireless Security Practice
Social Media Login
Social media is huge part of our lives, it is easier to and more convenient to let your guest login to your Wi-Fi by using their social media credential. Ruijie Cloud provides an ease of use integrated Facebook for guest Wi-Fi login.
A simple captive portal with Facebook login button can be built easily by using step by step wizard. No web programming skill is required!
Simple Captive Portal with Facebook Login Button
Fast Provisioning
Ruijie Cloud provides a mobile APP which allows devices onboarding and provisioning completed by just 4 simple steps. Typically, it takes less than 5 minutes from unboxing Ruijie wireless access point to Wi-Fi up and running, which significantly simplifies Wi-Fi deployment.
4-step Quick Provisioning
Mobile Operation On-The-Go
Ruijie Cloud offers an innovative breakthrough which allows device operation and management from your smartphones at your fingertips. Now you can monitor your Wi-Fi user experience, traffic and client analysis anytime and anywhere. An alarm notification will be pushed to your smartphone if there’s device issue found in your network. It helps SME business to know and understand the real time situation of Wi-Fi network.
Monitoring Wi-Fi Networking on your fingertips
Ruijie AP730-L
Ruijie AP720-L
Ruijie AP710
Ruijie AP210-L
Ruijie AP730-L
Ruijie AP720-L
Ruijie AP710
Ruijie AP210-L
Target Deployment
SME High Density Wi-Fi
Retail Chain Store, Small & Medium-sized Business Office, Boutique Hotel
Type
Indoor Ceiling/Wall-mounting
Basic Spec
Radio
Tri-band (2.4G+5G+5G)
Concurrent Dual-band
Single-band
Protocol
802.11a/b/g/n/ac
Wave2
802.11a/b/g/n/ac
802.11b/g/n
Operating Bands
802.11b/g/n: 2.4GHz to 2.483GHz
802.11a/n/ac: 5.150GHz to 5.350GHz, 5.47GHz to 5.725GHz, 5.725GHz to 5.850GHz (vary depending on countries)
Built-in Omni-directional Antenna
Antenna Gain
2.4G: 3dBi
5G: 3dBi
2.4G: 3dBi
Max Throughput
Maximum throughput of 2.4G: 400Mbps
Maximum throughput of 5G: 1.73Gbps
Maximum throughput per AP: 2.13Gbps
Maximum throughput of 2.4G: 300Mbps
Maximum throughput of 5G: 867Mbps
Maximum throughput per AP: 1167Mbps
Maximum throughput of 5G: 8.67Gbps
Maximum throughput per AP: 300Mbps
Modulation
OFDM:BPSK@6/9Mbps,QPSK@12/18Mbps,16-QAM@24Mbps,64-QAM@48/54Mbps
DSSS:DBPSK@1Mbps,DQPSK@2Mbps,and CCK@5.5/11Mbps
MIMO-OFDM:BPSK, QPSK, 16QAM, 64QAM, 256QAM
Receiver Sensitivity
11b:-96dBm(1Mbps),-93dBm(5Mbps),-89dBm(11Mbps)
11a/g:-91dBm(6Mbps),-85dBm(24Mbps),-80dBm(36Mbps),-74dBm(54Mbps)
11n:-90dBm(MCS0),-70dBm(MCS7),-89dBm(MCS8),-68dBm(MCS15)
11ac HT20:-88dBm(MCS0), -63dBm(MCS9)
11ac HT40:-85dBm(MCS0), -60dBm(MCS9)
11ac HT80:-82dBm(MCS0), -57dBm(MCS9)
11g:-91dBm(6Mbps),-85dBm(24Mbps),-80dBm(36Mbps),-74dBm(54Mbps)
Spatial Streams
2x2
2x2
2x2
2x2
Maximum Transmit Power
100mW
IP Rating
IP41
1 10/100/1000BASE-T Ethernet uplink
Port LAN1 supports PoE+
1 Console Port
1 Console Port
1 10/100BASE-T Ethernet uplink
Power
(DC Power adapters should be purchased from third-party vendors separately if needed.)
local power supply (DC 48V/0.6A)
PoE (802.3at)
local power supply (DC 5V/3A)
PoE (802.3af)
local power supply (DC 12V/1A)
PoE (802.3af)
Power Consumption
<25.5W
<12.95W
<7.5W
Maximum clients per AP
768
256
128
BSSID capacity
48
32
Support
Intelligent load balancing based on the number of users or traffic
Support
STA control
Support
Bandwidth control
Support
Preference for 5GHz (band select)
Support
Band Steering (5G Priority)
Support
PSK, Web, 802.1x authentication
Support
PPSK authentication
Support
Data encryption
WPA (TKIP), WPA2 (AES), WPA-PSK, and WEP (64 or 128 bits)
PEAP authentication
Support
Support
Rogue AP detection and countermeasure
Support
RADIUS
Support
Support
Wireless Intrusion Prevention System (WIPS)
Support
Routing
IPv4 address
Static IP address or DHCP reservation
IPv6 address
Manual or automatic configuration
Multicast to unicast conversion
Management and Maintenance
SNMP v1/v2C/v3, Telnet, TFTP, Web management
Cloud AC management
Support
FAT/FIT switching
Support
External Characteristics
Lock
Support
LED Indicators
1 LED indicator (red, green, blue, orange, and flashing modes, breathing flashing mode for smart device access, and the indicator can be switched off to enable silence mode)
Relevant Standard
Wi-Fi Alliance Certification
Support
Radio Standard
EN300 328
EN301 893
EMC Standard
GB9254
EN301 489-1
EN301 489-17
EN 61000
Safety Standard
GB4943
EN/IEC 60950-1
Dimensions (W x D x H) (mm)
230x230x42
194 × 194 × 37
175*175*25.8
1.3kg
0.42kg
0.35kg
Work Environment
Operating Temperature:
-10°C to 50°C
Storage Temperature:
-40°C to 70°C
-10°C to 45°C
-40°C to 70°C
Operating Humidity:
5% to 95% (non-condensing)
RG-AP730-L
Indoor 802.11ac Wave 2 Access Point, Tri-band (2.4G+5G+5G), 2 spatial streams, access rate up to 2.130Gbps, 1 10/100/1000BASE-T uplink port; Bundled with Ruijie Cloud Service lifetime license
(PoE and local power adapters sold separately)
Optional
RG-WS6008
WS Series Wireless Controller, 6 1000BASE-T ports, 2 1000BASE-T/1000BASE-X ports (combo), 32 APs License by default, maximum 200 APs or 400 Wall APs License
11ac Wave2 2x2 MU-MIMO
Tri-band (2.4G + 5G + 5G)
Up to 2.13Gbps
Max 768 Clients
Ruijie SME AP series is designed for the simplicity and ease of use application in many SME scenarios including small offices, boutique hotel, retail store and etc. We are helps SME to streamline the IT operational efficiency, reduce the Wi-Fi deployment complexity with cost effective approach. Ruijie Cloud Service is Ruijie's easy and efficient cloud solutions for chain stores, small and medium-sized businesses and boutique hotels. The solutions include equipment deployment, monitoring, network optimization and operational lifecycle management, enabling customers with simple plug-and-play deployment, operation and maintenance.
Ruijie Cloud Solution Highlights
Hardware Controller
For higher performance or stringent security scenarios, Ruijie offers the on-premise hardware controller option for flexible management. Ruijie provides comprehensive cost-effective enterprise-grade network solution to SME market, consisting of switches, wireless, gateways, security, etc. The solution provides customers with scenario-based AP options (indoor/wall AP), flexible WLAN management, reliable switch design with conformal coating protection, Layer 7 application protection and web filtering.
Ruijie WS6008 can be deployed as the wireless controller which simplifies the management of your wireless network by serving as a single point of management for all the access points in the network. Ruijie WS6008 supports up to maximum of 200 manageable access points, hence it increases the scalability and ensures your IT investment protection. Ruijie WS6008 offers full range of enterprise Wi-Fi features including rouge AP mitigation, automated Wi-Fi optimization (WIS), flexible authentication modes (web authentication, 802.1X), etc.
Comprehensive Solution for SME Market
Hardware Installation Guide
Product Datasheet
Datasheet
RGOS Configuration Guide
RGOS Command Reference
Software Download
Brochure
Technical Support
Technical Support
Get in Touch
Get in Touch
