| RG-N18000-E Series |
| Feature |
Description |
| Ethernet Switching |
| IEEE 802.3az EEE |
| IEEE 802.1Q (supporting 4K VLANs) |
| Voice VLAN |
| MAC address-based, port-based, protocol-based, and IP subnet-based VLAN assignment |
| GVRP |
| Basic QinQ and selective QinQ |
| STP (IEEE 802.1.d), RSTP (IEEE 802.1w), and MSTP (IEEE 802.1s) |
| ERPS (G.8032) |
| LLDP/LLDP-MED |
| IP Service |
Static and dynamic ARP |
| DHCP client |
| DHCP relay |
| DHCP server |
| DHCP snooping |
| DNS |
| DHCPv6 client, DHCPv6 relay, and DHCPv6 snooping |
| IPv4 and IPv6 GRE tunnel |
| IPv6 manual tunnel, IPv6 automatic tunnel, and IPv6 ISATAP tunnel |
| IP Routing |
Static routing |
| RIP and RIPng |
| OSPFv2 and OSPFv3 |
| GR |
| IS-ISv4 and IS-ISv6 |
| BGP4 and BGP4+ |
| IPv4/IPv6 VRF |
| IPv4/IPv6 PBR |
| Multicast |
IGMPv1/v2/v3 |
| IGMPv1/v2 snooping |
| IGMP proxy |
| IGMP fast leave |
| PIM-DM, PIM-SM, PIM-SSM, and other multicast routing protocols |
| Multicast static routing |
| PIM-SM, PIM-SSM, PIM-SMv6, and PIM-SSMv6 |
| MSDP for inter-domain multicast |
| MLDv1/v2 |
| MLDv1 snooping |
| Multicast source IP address check Multicast source port check Validity check of IGMP packets |
| Multicast querier |
| MPLS |
MPLS L3VPN |
| MPLS 6VPE and MPLS 6PE |
| MPLS IPv6 |
| MPLS MIB (RFC 1273, 4265, 4382) |
| ACL and QoS |
Standard IP ACLs (hardware ACLs based on IP addresses) |
| ACL80 and IPv6 ACL |
| Applying ACLs globally (hardware ACLs based on flexible combinations of the VLAN ID, Ethernet type, MAC address, IP address, TCP/UDP port number, protocol type, and time range) |
| ACL redirection |
| Port traffic identification |
| Port traffic rate limiting |
| IEEE 802.1p |
| Traffic classification based on 802.1p priorities, DSCP priorities, and IP precedences |
| Congestion management: SP, WRR, DRR, WFQ, SP+WRR, SP+DRR, SP+WFR, and SP+WFQ |
| Rate limiting based on the inbound or outbound interface |
| Eight queues on each port |
| Security |
Multi-AAA |
| RADIUS authentication, authorization, and accounting |
| TACACS+ |
| IEEE 802.1X |
| Web authentication |
| Hypertext Transfer Protocol Secure (HTTPS) |
| SSHv1 and SSHv2 |
| Global IP-MAC binding |
| ICMP (discarding ICMP packets of which the rate exceeds the threshold on an interface) |
| Port security |
| IP source guard |
| SAVI |
| ARP spoofing prevention |
| CPP and NFPP |
| Various attack defense functions including NFPP, ARP anti-spoofing, DHCP/DHCPv6 attack defense, ICMP attack defense, ND attack defense, IP scanning attack defense, and customizing attack defense packet types |
| Loose and strict RPF uRPF ignoring default routes |
| Reliability |
REUP |
| Rapid Link Detection Protocol (RLDP), Layer 2 link connectivity detection, unidirectional link detection, and VLAN-based loop control |
| Data Link Detection Protocol (DLDP) |
| IPv4/IPv6 ECMP |
| IPv4 VRRP v2/v3 and IPv6 VRRP v3 |
| BFD |
| Link monitoring, fault notification, and remote loopback based on 802.3ah (EFM) |
| 1+1 redundancy for supervisor modules |
| N+M redundancy for power modules |
| Hot patching for online patch upgrade |
| GR for OSPF/IS-IS/BGP |
| BFD for VRRP/OSPF/BGP4/IS-IS/IS-ISv6/static routing |
| Hot swapping of supervisor modules, switch fabric modules, power modules, and fan modules |
| Device Virtualization |
VSU |
| NMS and Maintenance |
SPAN, RSPAN, and ERSPAN |
| sFlow (network detection technology based on packet sampling, which is mainly used for traffic statistics and analysis in heavy-traffic scenarios) |
| N:1 mirroring, 1:N mirroring, and flow-based mirroring VLAN mirroring |
| NTP and SNTP |
| FTP, SFTP, TFTP, and Xmodem |
| SNMP v1/v2/c3 |
| RMON (1, 2, 3, 9) |
| Various types of RMON groups, including event groups, alarm groups, history groups, and statistics groups, as well as private alarm extension groups RMON used to implement Ethernet statistics, historical statistics, and alarm functions |
| NETCONF |
| CWMP |
| gRPC |
| OpenFlow Special 1.3 |
| Flow table analysis defined by all protocols Transmission of specified packets to the controller Configuring the controller's IP address and port Notifying port status changes to the controller |
| Web-based NMS |
| VXLAN |
EVPN VXLAN tunnel establishment LAN access to VXLAN IPv4 over IPv4 Distributed gateway IPv6 over IPv6 Using an SVI to connect to the VXLAN network Using a routed interface to connect to the VXLAN network Proxy ARP (replying with the actual MAC address)) ND proxy (replying with the actual MAC address) ND reply (replying with the actual MAC address) VXLAN static route Anycast gateway VXLAN bridging mode VXLAN routing mode Proxy ARP (replying with the gateway MAC address) Configuring the UDP port number in VXLAN packets Static VXLAN tunnel creation Layer 2 VXLAN bridge Layer 3 VXLAN gateway EVPN VXLAN |
