RG-S5310-48GT4XS-E 48-Port GE Electrical Layer 3 Managed Access Switch, Four 10G Uplink Ports
  • Rich port types, 48 x 1000 Mbps Ethernet ports, 4 x 10G optical ports for uplink
Thông số chi tiết chính
Layer 3 Access Switch for 10G Uplink RG-S5310-48GT4XS-E
Full-gigabit access switch for large-sized enterprise and campus LANs, with four 10G uplink optical ports for high-speed data transmission 48 x 1000 Mbps Ethernet ports with auto-negotiation, providing high-speed network experience for short-distance services
Hot-Swappable Dual Power Modules, Dual Protection for Links
Hot-swappable dual power modules are provided for 1+1 power redundancy. Seamless power module failover can be realized if one power module fails, providing dual protection for links
achieving automatic O&M.
FAQ
Tài liệu
RG-S5310-24GT4XS-E
RG-S5310-24GT4XS-P-E
RG-S5310-48GT4XS-E
RG-S5310-48GT4XS-P-E
Interface Specifications
Fixed Ports
24x10/100/1000 BASE-T ports
4 x 1G/10G SFP+ ports
24x 10/100/1000 BASE-T ports
4x 1G/10G SFP+ ports
Supports PoE Standards
 IEEE 802.3af, 802.3at
48 x 10/100/1000 BASE-T ports
Supports PoE Standards IEEE 802.3af, 802.3at
Power Supplies
1+1 redundancy of power modules
1+1 redundancy of power modules Up to 720 W of PoE+
1+1 redundancy of power modules Up to 1,440 W of PoE+
1 MGMT port, 1 console port, and 1 USB port, compliant with USB2.0 standard
System Switching Capacity
3.36Tbps
3.36Tbps
4.32Tbps4
4.32Tbps4
Packet Forwarding Rate
126Mpps
126Mpps
166Mpps
166Mpps
No. of VSU Members
MAC Address
128000
ARP Table
4k,16k(authorized)
4k,16k(authorized)
4k,16k(authorized)
4k,16k(authorized)
Routing Table Size
(IPv4)
8K,12k(authorized)
8K,12k(authorized)
8K,12k(authorized)
8K,12k(authorized)
Routing Table Size
(IPv6)
4k
4k
4k
4k
ACL Entries
In: 3500
Out:1500
In: 3500
Out:1500
In: 3500
Out:1500
In: 3500
Out:1500
CPU and Storage
Dual-Core CPU, 1.2GHz
Flash Memory
2GB
Dimensions (W × D × H)
442 mm × 420 mm × 43.6 mm,1 RU
4.2KG(9.26 lbs)
4.3KG (9.48 lbs)
4.3KG (9.48 lbs)
4.6KG (10.14 lbs)
Power and Consumption
Rated Voltage
S5310-24GT4XS-E、RG-S5310-48GT4XS-E ,AC input:
Rated voltage range: 100 V to 240 V
Frequency: 50/60 Hz
RG-S5310-24GT4XS-P-E、RG-S5310-48GT4XS-P-E,AC input:
Rated voltage range: 200 V to 240 V
Maximum Voltage
RG-S5310-24GT4XS-E、RG-S5310-48GT4XS-E ,AC input:
Maximum voltage range: 90 V to 264 V
Frequency: 50/60 Hz
RG-S5310-24GT4XS-P-E、RG-S5310-48GT4XS-P-E, AC input:
Maximum voltage range: 176 V to 264 V
Maximum Power Consumption
 ≤40W
<85W(Non POE)
<810W (PoE full load)
≤55W
<75W(Non POE)
<1570W (PoE full load)
Operating temperature: 0℃~45℃
Storage temperature: -40℃ to 70℃
Relative Humidity
Operating humidity: 10% to 90%RH
Storage humidity: 5% to 95%RH
Lightning Protection
10KV (Service Interface)
4KV (MGMT Interface)
Fan Monitoring
Fan speed regulating and alarm function
RG-S5310-E Series
Ethernet Switching
Super VLAN and private VLAN
Auto errdisable recovery
BPDU filter
Port fast
Root guard
DHCPv6 client, DHCPv6 relay, DHCPv6 server, and DHCPv6 snooping
MAC address filtering
GRE tunnel
IP Routing
IPv4 and IPv6 static routing
OSPFv2, OSPFv3, and GR
IPv4/IPv6 PBR
IGMPv1/v2 snooping
PIM-DM, PIM-SM, PIM-SSM, PIM SMv6, and PIM-SSMv6
MLDv1/v2 and MLD proxy
MLDv1/v2 snooping
MAB authentication
IPv4 VRRP v2/v3, IPv6 VRRP, and super-VLAN for VRRP
Basic LACP
Inter-VSU AP
Hot swapping of power modules
Local and remote stacking
RSPAN and ERSPAN
SNTP
CLI (Telnet/Console)
SNMP v1/v2/c3
Web
Syslog/Debug
MACC
1:1 mirroring
N:1 mirroring
1:N mirroring
VXLAN (authorized)
Protocol Compliance
RG-S5310-E Series
Organization
Standards and Protocol
IETF
RFC 1058 Routing Information Protocol (RIP)
RFC 1157 A Simple Network Management Protocol (SNMP)
RFC 1305 Network Time Protocol Version 3 (NTP)
RFC 1349 Internet Protocol (IP)
RFC 1350 TFTP Protocol (revision 2)
RFC 1519 CIDR
RFC 1583 OSPF Version 2
RFC 1591 Domain Name System Structure and Delegation
RFC 1643 Ethernet Interface MIB
RFC 1757 Remote Network Monitoring (RMON)
RFC 1812 Requirements for IP Version 4 Router
RFC 1901 Introduction to Community-based SNMPv2
RFC 1902-1907 SNMP v2
RFC 1918 Address Allocation for Private Internet
RFC 1981 Path MTU Discovery for IP version 6
RFC 1997 BGP Communities Attribute
RFC 2131 Dynamic Host Configuration Protocol (DHCP)
RFC 2132 DHCP Options and BOOTP Vendor Extensions
RFC 2236 IGMP
RFC 2328 OSPF Version 2
RFC 2385 Protection of BGP Sessions via the TCP MD5 Signature Option
RFC 2439 BGP Route Flap Damping
RFC 2460 Internet Protocol, Version 6 (IPv6)
RFC 2461 Neighbor Discovery for IP Version 6 (IPv6)
RFC 2462 IPv6 Stateless Address Auto configuration
RFC 2463 Internet Control Message Protocol for IPv6 (ICMPv6)
RFC 2545 Use of BGP 4 Multiprotocol Extensions for IPv6 Inter Domain Routing
RFC 2571 SNMP Management Frameworks
RFC 2711 IPv6 Router Alert Option
RFC 2787 Definitions of Managed Objects for the Virtual Router Redundancy Protocol
RFC 2863 The Interfaces Group MIB
RFC 2865 Remote Authentication Dial In User Service (RADIUS)
RFC 2918 Route Refresh Capability for BGP 4
RFC 2925 Definitions of Managed Objects for Remote Ping, Traceroute, and Lookup Operations (Ping only)
RFC 2934 Protocol Independent Multicast MIB for IPv4
RFC 3046 DHCP Option82
RFC 3065 Autonomous System Confederation for BGP
RFC 3101 OSPF Not so stubby area option
RFC 3137 OSPF Stub Router Advertisement sFlow
RFC 3417 (SNMP Transport Mappings)
RFC 3418 Management Information Base (MIB) for the Simple Network Management Protocol (SNMP)
RFC 3509 Alternative Implementations of OSPF Area Border Routers
RFC 3513 IP Version 6 Addressing Architecture
RFC 3575 IANA Considerations for RADIUS
RFC 3579 RADIUS Support For EAP
RFC 3623 Graceful OSPF Restart
RFC 3768 VRRP
RFC 3810 Multicast Listener Discovery Version 2 (MLDv2) for IPv6
RFC 3973 PIM Dense Mode
RFC 4022 MIB for TCP
RFC 4271 A Border Gateway Protocol 4 (BGP 4)
RFC 4273 Definitions of Managed Objects for BGP 4
RFC 4360 BGP Extended Communities Attribute
RFC 4456 BGP Route Reflection: An Alternative to Full Mesh Internal BGP (IBGP)
RFC 4486 Subcodes for BGP Cease Notification Message
RFC 4552 Authentication/Confidentiality for OSPFv3
RFC 4724 Graceful Restart Mechanism for BGP
RFC 4750 OSPFv2 MIB partial support no SetMIB
RFC 4760 Multiprotocol Extensions for BGP 4
RFC 4940 IANA Considerations for OSPF
RFC 5065 Autonomous System Confederation for BGP
RFC 5187 OSPFv3 Graceful Restart
RFC 5340 OSPFv3 for IPv6
RFC 5492 Capabilities Advertisement with BGP 4
RFC 6620 FCFS SAVI
RFC 768 User Datagram Protocol (UDP)
RFC 783 TFTP Protocol (revision 2)
RFC 792 Internet Control Message Protocol (ICMP)
RFC 793 Transmission Control Protocol (TCP)
RFC 813 Window and Acknowledgement Strategy in TCP
RFC 815 IP datagram reassembly algorithms
RFC 826 Ethernet Address Resolution Protocol (ARP)
RFC 854 Telnet Protocol
RFC 959 File Transfer Protocol (FTP)
IEEE
IEEE 802.2 Logical Link Control
IEEE 802.1ab Link Layer Discovery Protocol
IEEE 802.1ad Provider Bridges
IEEE 802.1ax/IEEE802.3ad Link Aggregation
IEEE 802.1D Media Access Control (MAC) Bridges
IEEE 802.1D Spanning Tree Protocol
IEEE 802.1Q Virtual Bridged Local Area Networks (VLAN)
IEEE 802.1s Multiple Spanning Tree Protocol
IEEE 802.1w Rapid Spanning Tree Protocol
IEEE 802.3ad Link Aggregation Control Protocol (LACP)
IEEE Std 802.3x Full Duplex and flow control
IEEE 802.3bt Power over Ethernet (supported by PoE-capable models)
Industry Certificates
Electromagnetic Compatibility (EMC) Standards:
✓CISPR 22/EN 55032 (Conducted and Radiated Emissions)
✓EN 55035 (Immunity)
✓IEC/EN 61000-4-2 or ANSI/ESD S20.20 (Electrostatic Discharge - ESD)
✓IEC/EN 61000-4-3 (Radio Frequency Electromagnetic Field)
✓IEC/EN 61000-4-4 (Electrical Fast Transient -EFT)
✓IEC/EN 61000-4-5 (Surge Immunity)
✓IEC/EN 61000-4-6 (Radio Frequency Common Mode)
✓IEC/EN 61000-4-11 (Voltage Dips and Interruptions)
✓IEC/EN 61000-3-2(Voltage Dips and Interruptions)
✓IEC/EN 61000-3-2 (Voltage Dips and Interruptions)
• Safety Standards:
✓IEC 60950/EN 62368
✓IEC 60068
✓RoHS or WEEE (Environmental)
RG-S5310--24GT4XS-E
24 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports
24 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE and the maximum PoE output power of 740 W.
RG-S5310-48GT4XS-E
48 x 10/100/1000M auto-negotiation electrical ports, 4 x 1G/10G SFP+ ports
48 x 10/100/1000M adaptive electrical ports, 4 x 1G/10G SFP+ ports, supporting PoE and the maximum PoE output power of 1440 W
RG-PA70IB
70 W AC power module
600 W AC power module, PoE power module
RG-VXLAN-MPLS-ENTRY-LIC
S5310E series, software license for VXLAN, MPLS, routing table, and ARP table
1000BASE-GT mini GBIC module
Mini-GBIC-SX-MM850
Single-port 1000BASE-SX mini GBIC module (LC)
Mini-GBIC-LX-SM1310
Single-port 1000BASE-LX mini GBIC module (LC)
Mini-GBIC-LH40-SM1310
Single-port 1000BASE-LH mini GBIC module (LC), supporting a transmission distance of 40 km
Mini-GBIC-ZX100-SM1550
1000BASE-ZX mini GBIC module, supporting a transmission distance of 100 km
10G LC interface module (62.5/125 μm: 33 m; 50/125 μm: 66 m; 300-meter transmission at modal bandwidth of 2000 MHz•km), applicable to SFP+ ports
10G LC interface module (1310 nm), 10 km, applicable to SFP+ ports
10G LC interface module (1550 nm), 40 km, applicable to SFP+ ports
Technical Support
Technical Support
Get in Touch
Get in Touch
