  • 2.5GE uplink, which can upgrade gigabit networks to 10GE networks, and meet 40GE/100GE networking requirements in the future
  • Streamline O&M and Management with Onsite INC and WIS Cloud-based Solutions
RG-S5000-24GT4MS-E
Switching capacity: 68 Gbps
Forwarding rate: 51 Mpps
and Wider Coverage
10 kV Surge Protection
RLDP can quickly discover loops caused by unauthorized connection of the port to a hub and other devices, and take corresponding measures to prevent broadcast storms and and ensure the security of the device and the link.
Local & Cloud O&M
Visualized Management
Alarm Processing
FAQ
Tài liệu
RG-S5000-10GT2MS-E
RG-S5000-10GT2MS-P-E
RG-S5000-24GT4MS-E
RG-S5000-24GT4MS-P-E
RG-S5000-48GT4MS-E
Interface Specifications
Fixed port
10 x 10/100/1000Base-T Ethernet ports with auto-negotiation
2 x 2.5GE/1GE SFP ports
PoE/PoE+ supported
24 x
4 x 2.5G/1GE SFP ports
24 x 10/100/1000Base-T Ethernet ports with auto-negotiation
4 x 2.5GE/1GE SFP ports
PoE/PoE+ supported
48 x 10/100/1000Base-T Ethernet ports with auto-negotiation
1 x fixed module
0
1 x fixed module
0
2 x fixed modules
2 x fixed modules
1 x RJ45 console port and 1 x USB port
22.5 Mpps
22.5 Mpps
51 Mpps
51 Mpps
87 Mpps
System switching capacity
30 Gbps
30 Gbps
68 Gbps
68 Gbps
116 Gbps
MAC address
16000
512
ND table size
256
500
260 mm x 170 mm x 43.6 mm (10.24 in. x 6.69 in. x 1.72 in.), 1 RU
297 mm x 170 mm x 43.6 mm (11.69 in. x 6.69 in. x 1.72 in.), 1 RU
440 mm x 220 mm x 43.6 mm (17.32 in. x 8.66 in. x 1.72 in.), 1 RU
Weight (full load)
2 kg (4.41 lbs)
2.5 kg (5.51 lbs)
2.5 kg (5.51 lbs)
2.8 kg (6.17 lbs)
2.8 kg (6.17 lbs)
CPU and Storage
ARM Cortex A9, 1.2 GHz
Storage
512 MB SDRAM
64 MB flash memory
Data packet buffer
512 KB
512 KB
512 KB
512 KB
512 KB
Power and Consumption
16 W
141 W (PoE power: 125 W)
15.6 W
430 W (PoE power: 370 W)
30 W
Rated input voltage
100 V AC to 240 V AC @50 Hz/60 Hz
Maximum input voltage
90 V AC to 264 V AC @50 Hz/60 Hz
> 200K
> 200K
> 200K
> 200K
> 200K
Primary airflow
Natural heat dissipation
Forced air cooling
Forced air cooling
Forced air cooling
0°C to 45°C (32°F to 113°F)
5% to 95% RH (non-condensing)
Operating altitude
–500 m to +5,000 m (–1640.42 ft. to + 16404.20 ft.)
Above an altitude of 1800 m (5905.51 ft.), the operating temperature can decrease.
Operating noise
40 dB
40 dB
40 dB
Interface surge protection
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Common mode 10 kV
Others
Installation mode
RG-S5000-E Series
Port-based VLAN assignment
Basic QinQ and selective QinQ
DNS client
Neighbor Discovery (ND)
OSPFv2
IGMP snooping v1/v2
Expert ACLs
ACL 80
Port rate limiting
IEEE 802.1X authentication
SSHv1.5 and SSHv2.0
Proxy ARP and ARP entry aging
Hardware CPP and NFPP
LACP
Load balancing modes
RSPAN
TFTP (TFTP client)
SSH v1.5/v2.0
l IEEE 802.3af and 802.3at
l Automatic and energy-saving power supply management mode
l Uninterrupted power supply in hot start mode
l Scheduled powering on or off PoE ports
l Port priority
Cloud
WIS
RG-S5000-10GT2MS-E
10 x 10/100/1000Base-T electrical ports with auto-negotiation, 2 x 1GE/2.5GE SFP ports, fixed single AC power supply
10 x 10/100/1000Base-T electrical ports with auto-negotiation, 2 x 1GE/2.5GE SFP ports, fixed single AC power supply, ports 1 to 8 supporting PoE/PoE+ power supply, and maximum PoE output power of 125 W
RG-S5000-24GT4MS-E
24 x 10/100/1000Base-T electrical ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply
24 x 10/100/1000Base-T electrical ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply, PoE/PoE+ power supply, and maximum PoE output power of 370 W
RG-S5000-48GT4MS-E
48 x 10/100/1000Base-T electrical ports with auto-negotiation, 4 x 1GE/2.5GE SFP ports, fixed single AC power supply
SFP 2.5G BIDI transceiver-TX1310/RX1550, 3 km, LC
SFP 2.5G BIDI transceiver-TX1550/RX1310, 3 km, LC
1000BASE-SX, SFP transceiver, SM (850 nm, 500 m, LC).
1000BASE-LX, SFP transceiver, SM (1310 nm, 10 km, LC)
1000BASE-LH, SFP transceiver, SM (1310 nm, 40 km, LC)
1000BASE-ZX80, SFP transceiver, SM (1550 nm, 80 km, LC)
SFP BIDI Transceiver-TX1310/RX1550, 20 km, LC
SFP BIDI Transceiver-TX1550/RX1310, 20 km, LC
SFP BIDI Transceiver-TX1310/RX1550, 40 km, LC
SFP BIDI Transceiver-TX1550/RX1310, 40 km, LC
1000BASE-TX, SFP transceiver (100 m)
User Experience Questionnaire
We cordially invite you to participate in the user experience survey on our official website. Your feedback will help us build a better platform.
No
Technical Support
Technical Support
Get in Touch
Get in Touch
