Home> Sản phẩm> Thiết bị chuyển mạch> Access Switches>
RG-S2900G-E V3 Series Switches
Feature Highlights:
Ruijie RG-S2900G-E V3 Series is a collection of next-gen multiservice switches, offering remarkable performance and enhanced security. Implementing an industry-leading hardware design and Ruijie’s latest RGOS11.X modular operating system, the switches offer better table capacity, improved hardware processing performance, and easier user operation.
Xem thêm+
The RG-S2900G-E V3 Series effectively prevents and controls virus spread and hacker attacks with various inherent mechanisms such as anti-DoS attacks, hacker IP scanning, illegal ARP packets checking and multiple hardware ACL policies.
Industry-leading CPU protection mechanism: The CPU Protect Policy (CPP) provides policies for protecting the CPU of a switch. In network environments, various attack packets spread, which may cause high CPU usages of the switches, affect protocol running and even difficulty in switch management. To this end, switch CPUs must be protected, that is, traffic control and priority-based processing must be performed for various incoming packets to ensure the processing capabilities of the switch CPUs.
o CPP can effectively prevent malicious attacks in the network and provide a clean environment for legitimate protocol packets.
o CPP is enabled by default. It provides protection during the entire operation of switches.
NFPP: Network Foundation Protection Policy (NFPP) provides guards for switches. Malicious attacks are always found in the network environment. These attacks bring heavy burdens to switches, resulting in high CPU usage and operational troubles. These attacks are as follows:
o Denial of Service (DoS) attacks may consume lots of memory, entries, or other resources of a switch, which will cause system service termination.
o Massive attack traffic is directed to the CPU, occupying the entire bandwidth of the CPU. In this case, normal protocol traffic and management traffic cannot be processed by the CPU, causing protocol flapping or management failure. The forwarding in the data plane will also be affected and the entire network will become abnormal.
NFPP can effectively protect the system from these attacks. Facing attacks, NFPP maintains the proper running of various system services with a low CPU load, thereby ensuring the stability of the entire network.
NFPP Network Protection
Virtual Switch Unit (VSU)
Millisecond failover: The VSU and peripheral devices are connected via the aggregation link. Upon failure event of any device or link, failover to another member link requires only 50 to 200ms.
Simplified Network Topology Enable by VSU
High Reliability
The RG-S2900G-E V3 Series supports spanning tree protocols of 802.1d, 802.1w, and 802.1s to ensure rapid convergence, improves fault tolerance capabilities, ensures stable running of networks and load balancing of links, and provides redundant links.
Ethernet Ring Protection Switching (ERPS) (G.8032): Implements loop blocking and link recovery on the master device. Other devices directly report link status to the master device. Without passing through other standby devices, the failover time of loop interruption and recovery is hence faster than STP. The ERSP’s link failover rate can be completed within milliseconds under ideal conditions.
Rapid Ethernet Uplink Protection Protocol (REUP): When Spanning Tree Protocol (STP) is disabled, the Rapid Ethernet Uplink Protection Protocol (REUP) can provide basic link redundancy through the rapid uplink protection function and provide faster subsecond-level fault recovery than STP.
With the all-new hardware architecture and Ruijie’s latest RGOS11.X modular operating system, the RG-S2900G-E V3 Series fully supports OpenFlow 1.3. in collaboration with Ruijie’s SDN controller, it forms a large-scale Layer 2 networking architecture with ease. Smooth upgrade of the whole network to a SDN one is also enabled. The switch series hence greatly simplifies the network management and minimizes network deployment savings.
Energy Efficiency
The RG-S2900G-E V3 Series adopts next-gen hardware architecture with a highly energy-saving circuit design and component selection. The device achieves a marked reduction in energy consumption. In addition to maximized energy saving, the RG-S2900G-E V3 Series also significantly lowers noise pollution. All models in the series deploy variable-speed axial fans, which support intelligent speed adjustment based on the current ambient temperature. All the features enable the switches to work smoothly and reduce power consumption and noise pollution at the same time.
The RG-S2900G-E V3 Series also supports auto-power-down mode. When an interface is down for a certain period of time, the system will automatically power it down for extra energy efficiency. EEE energy-saving mode is another feature highlight. The system will automatically turn an idle port into energy-saving mode. When there is a new packet, the system will issue listening streams to the port to resume service.
Easy Network Maintenance
The RG-S2900G-E V3 Series supports abundant features such as SNMP V1/V2/V3, RMON, Syslog, and logs and configuration backup using USB for routine diagnosis and maintenance. Administrators can use a wide variety of methods for easier management and such include CLI, web management, Telnet, CWMP(TR069),etc.
 The RG-S2900G-E V3 Series fully supports RG-SNC (Smart Network Commander) which is a network management system launched by Ruijie Networks especially designed for network performance management and configuration. With a friendly browser UI, the SNC provides an extensive array of features such as network topology display, device management, performance monitoring, configuration & software management, real-time alarm and log & report management.
RG-SNC Topology Management
Design For Durability
In the corrosive gas, high humidity environment, electronic products will accelerate corrosion, reliability and lifetime will be shortened, However, deployment environments of access switch are different, there may be lack of temperature and humidity regulation and close to the source of pollution or the sea. Through the design for durability, RG-S29E V3 series switches can operate stably in a variety of deployment environments.
Fanless design: If the air flow on the surface of the electronic product is too fast, it will increase the degree of gas corrosion of the equipment and shorten the service life of the equipment. For low-power products, fanless design is the most effective anti-corrosion measures. The RG-S2928G-E uses a fanless design to reduce corrosive gases and dust ingress.
RG-S2928G-E V3
RG-S2952G-E V3
24 10/100/1000BASE-T ports
4 1G SFP ports (non-combo)
48 10/100/1000BASE-T ports
Fan Slots
Fixed
Management Ports
1 console port
Switching Capacity
Up to 256Gbps
Packet Forwarding Rate
Up to 96Mpps
Up to 132Mpps
Port Buffer
1.5MB
ARP Table
MAC Address
Up to 16K
Routing Entries
500
IP Host Entries
(IPv4/IPv6)
500 (IPv4/IPv6)
ACL Entries
Up to 1,500
Standard/Extended/Expert ACL, Extended MAC ACL, ACL 80, IPv6 ACL, ACL logging, ACL counter, ACL remark, Global ACL, ACL redirect
802.1p/DSCP/TOS traffic classification; Multiple queue scheduling mechanisms, such as SP, WRR, DRR, SP+WFQ, SP+WRR, SP+DRR; Input port-based speed limit; Port-based traffic recognition; Each port supports 8 queue priorities
4K 802.1q VLANs, Port-based VLAN, MAC-based VLAN, Protocol-based VLAN, Private VLAN, Voice VLAN, QinQ, IP subnet-based VLAN, GVRP
QinQ
Basic QinQ, Flexible QinQ, 1:1 VLAN switching
Link Aggregation
AP, LACP, Flow balance
Port Mirroring
Many-to-one mirroring, One-to-Many mirroring, Flow-based mirroring, Over devices mirroring, VLAN-based mirroring, VLAN-filtering mirroring, AP-port mirroring, RSPAN, ERSPAN
Spanning Tree Protocols
IEEE802.1d STP, IEEE802.1w RSTP, Standard 802.1s MSTP, Port fast, BPDU filter, BPDU guard, TC guard, TC filter, TC protection, LOOP guard, ROOT guard
DHCP
DHCP server, DHCP client, DHCP snooping, DHCP relay, IPv6 DHCP snooping, IPv6 DHCP client, IPv6 DHCP relay
Multiple Spanning Tree Protocol (MSTP) Instances
Maximum Aggregation Port (AP)
Up to 128
IGMP v1/v2/v3 snooping, IGMP SGVL/IVGL, IGMP filter, IGMP fast leave, MLD snooping v1/v2
SDN
OpenFlow 1.0, future support OpenFlow 1.3
EEE Format
Support IEEE 802.3az standard
G.8032
Support
L2 Features
MAC, EEE, ARP, VLAN, Basic QinQ, Felix QinQ, Link aggregation, Mirroring, STP, RSTP, MSTP, Broadcast storm control, IGMP v1/v2/v3 snooping, IGMP SGVL/IVGL, IGMP filter, IGMP fast leave, DHCP, Jumbo frame, RLDP, LLDP, REUP, G.8032 ERPS, Layer 2 protocol tunnel
Layer 2 Protocols
IEEE802.3, IEEE802.3u, IEEE802.3z, IEEE802.3x, IEEE802.3ad, IEEE802.1p, IEEE802.1x, IEEE802.3ab, IEEE802.1Q (GVRP), IEEE802.1d, IEEE802.1w, IEEE802.1s
Binding of the IP address, MAC address, and port address; Binding of the IPv6, MAC address, and port address; Filter illegal MAC addresses; Port-based and MAC-based 802.1x; MAB; Portal and Portal 2.0 authentication; ARP-check; DAI; Restriction on the rate of ARP packets; Gateway anti-ARP spoofing; Broadcast suppression; Hierarchical management by administrators and password protection; RADIUS and TACACS+; AAA security authentication (IPv4/IPv6) in device login management; SSH and SSH V2.0; BPDU guard; IP source guard; CPP, NFPP; Port protection
Layer 3 Features
IPv4 static routing, IPv6 static routing, RIP, RIPng, OSPFv2/v3, ARP proxy, Neighbor Discovery,VRRP
Layer 3 Protocols (IPv4)
Static routing, RIP, RIPng, OSPFv2/v3
IPv4 Features
Ping, Traceroute
IPv6 Features
0-64 any length mask, ICMPv6, Neighbor Discovery, Manually configure local address, Automatically create local address,  IPv6 Ping, IPv6 Tracert, IPv6 extender option head,VRRP v3
Basic IPv6 Protocols
IPv6 addressing, Neighbor Discovery (ND), IPv6 ACL, ICMPv6, IPv6 Ping, IPv6 Tracert
IPv6 Routing Protocols
Static routing, RIPng, OSPFv3
VSU (Virtual Switch Unit)
Support (up to 9 stack members,to ensure the effectiveness of the use, 4 members are recommended)
Zero Configuration
CWMP(TR069)
RAS
VSU (virtualization technology for virtualizing multiple devices into 1); GR for RIP/OSPF;  ERPS (G.8032); REUP dual-link fast switching technology; RLDP (Rapid Link Detection Protocol)
Manageability
SNMPv1/v2c/v3, CLI (Telnet/Console), RMON (1, 2, 3, 9), SSH, Syslog/Debug, RSPAN/ERSPAN, NTP/SNTP, FTP, TFTP, Web, SFLOW,support cable detection and port sleep mode
Smart Temperature Control
Auto fan speed adjustment; Fan malfunction alerts; Fan status check
Other Protocols
FTP, TFTP, DNS client, DNS static
(W x D x H) (mm)
440 × 260 × 43.6
Rack Height
1RU
≤3.5kg
≤4kg
482560 hours
372690 hours
Lightning Protection
6KV
AC input:
Rated voltage range: 100V to 240V AC
Maximum voltage range: 90V to 264V AC
Frequency: 50 to 60Hz
HVDC input:
Input voltage range: 192V to 290V DC
Power Consumption
≤24W
≤40W
Operating temperature: 0°C to 50°C
Storage temperature: -40°C to 70°C
Operating humidity: 10% to 90%RH
Storage humidity: 5% to 95%RH
Operating Altitude
-500m to 5,000m
Safety Standards
IEC 60950-1,EN60950-1
Emission Standards
EN 300 386, EN 55032, EN 61000-3-2, EN 61000-3-3, EN 55024, EN 61000-4-2, EN 61000-4-3, EN 61000-4-4, EN 61000-4-5, EN 61000-4-6, EN 61000-4-8, EN 61000-4-11
RG-S2928G-E V3
RG-S2952G-E V3
1000BASE-GT mini GBIC Transceiver
1000BASE-SX mini GBIC Transceiver (850nm)
1000BASE-LX mini GBIC Transceiver (1310nm)
1000BASE-LH mini GBIC Transceiver (1310nm, 40km)
MINI-GBIC-ZX50-SM1550
1000BASE-ZX mini GBIC Transceiver (1550nm, 50km)
1000BASE-ZX mini GBIC Transceiver (1550nm, 80km)
MINI-GBIC-ZX100-SM1550
1000BASE-ZX mini GBIC Transceiver (1550nm, 100km)
1000BASE-LX, SFP Transceiver, BIDI-TX1310/RX1550,20km,LC
1000BASE-LX, SFP Transceiver, BIDI-TX1550/RX1310,20km,LC
1000BASE-LH, SFP Transceiver, BIDI-TX1310/RX1550,40km,LC
1000BASE-LH, SFP Transceiver, BIDI-TX1550/RX1310,40km,LC
The RG-S2900-E/P V3 gigabit secure and intelligent access switches are ideal for the following and scenarios alike
Full gigabit access to LANs of large-scale enterprises and institutions, such as government buildings, large manufacturing, energy, and metallurgy enterprises Full gigabit access to server clusters
Secure access through flexible and diverse security control policies that can defend and control network viruses and attacks
Full gigabit access to business systems, such as hospitals, libraries, exhibition centers, and websites
This networking topology enables RG-S2900-E V3 series to cooperate with convergence switches (eg.RG-S5750-H) in an entire building and core switches (eg.RG-N18000 series) in the core area to provide gigabit services for desktops. The 10G high-bandwidth links converge in the core area to satisfy user requirements for increasing information volumes in universities, libraries, laboratories, financial centers, offices, and exhibition centers.
Hardware Installation Guide
Product Datasheet
Brochure
RGOS Configuration Guide
RGOS Command Reference
White Paper
Software Download
PoC Guide
SCN+ Higher Education Solution
Technical Support
Technical Support
Get in Touch
Get in Touch
