Feature Highlights:
Ruijie RG-RSR10-01G-T 4G Wireless Router is specifically designed for small and medium businesses to power next-gen network solutions. The leading device supports routing, switching, security, 4G/3G connection all in one to adapt to various deployment scenarios. Extensive software features are also available to support VPN, MPLS, multicast applications and so on. Together with a wide range of backup solutions and H-QoS features, the RG-RSR10-01G-T router is an ideal companion for access solutions involving data and videos.
The compact router is uniquely designed for 4G/3G wireless connection, offering Ruijie’s leading technologies such as VCPU, REF and X-Flow to protect against malicious attacks. A variety of H-QoS features enable secure deployment of multiple services at the same time. The RG-RSR10-01G-T router, with a built-in hardware encryption engine, ensures best-in-class security for key data protection.
With an industrial-grade design, the router delivers excellent performance under a wide temperature range. The internal 4G wireless module supports TD-LTE and FDD-LTE, and are backward compatible with 3G/2G standards enabling TD-SCDMA, WCDMA, GSM, etc. Convenient 802.11b/g/n. The RG-RSR10-01G-T router is an ideal match for self-service banking ATM centers and difficult-to-deploy sites such as islands, power plants, mines, petrol refineries and scenarios alike.
