Feature Highlights:
Ruijie RG-ES100 Series Switches are the next-generation unmanaged switches for scenarios like CCTV, ELV and small offices. The series is designed for small and medium-sized businesses looking for Plug-n-Play solution.
Ruijie RG-ES100 Series is part of the Ruijie SME networking products. The series consists of 3 switches including one 8-port Gigabit PoE+ models and two 24-port Gigabit PoE+ switch models.
These switches can be deployed with plug-and-play out the box. Moreover, port-isolation and flow-control features can be done with a simple flip with the button on the panel. Also, PoE budget status can be shown directly on port indicators, which helps a lot in trouble-shooting.
Key Features
● 24-port and 8 port Gigabit PoE for CCTV/ELV and other SME scenarios
● One-click button simple management beyond Plug-n-Play
● 370W and 180W PoE budget choices on 24-port models
● All 8/24 ports are PoE/PoE+ capable, feel free to choose any ports
● 3 year warranty free of charge
