LC Simplex, 1330nm-TX/1270nm-RX
XG-SFP-LR10-SM1270-BIDI-ILC Simplex, 1270nm-TX/1330nm-RX
XG-SFP-ZR-SM1550LC Duplex, SMF, 80 km
XG-SFP-LR-SM1310LC Duplex, SMF, 10 km
XG-SFP-ER-SM1550LC Duplex, SMF, 40 km
XG-SFP-SR-MM850LC Duplex, MMF, 300 m
XG-SFP-AOC5M5 m, 10G SFP+
XG-SFP-AOC1M1 m, 10G SFP+
XG-SFP-AOC3M3 m, 10G SFP+
| Model |
XG-SFP-SR-MM850 |
XG-SFP-LR-SM1310 |
XG-SFP-ER-SM1550 |
XG-SFP-ZR-SM1550 |
XG-SFP-LR10-SM1270-BIDI-I |
XG-SFP-LR10-SM1330-BIDI-I |
| Data rate |
10.3125 Gbps |
| Form factor |
SFP+ |
| Connector type |
Duplex LC |
Duplex LC |
Duplex LC |
Duplex LC |
BIDI LC |
BIDI LC |
| Cable type |
MMF |
SMF |
SMF |
SMF |
SMF |
SMF |
| Fiber end face finish type |
Ultra Physical Contact (UPC) |
| Transmitter type |
VCSEL |
DFB |
DFB |
DFB |
DFB |
DFB |
| Receiver type |
PIN |
| Reach |
300 m (984.25 ft., with OM3 optical cables) 400 m (1312.34 ft., with OM4 optical cables) |
10 km (32,808.40 ft.) |
40 km (131,233.60 ft.) |
80 km (262,467.19 ft.) |
10km (32,808.40.13 ft.) |
| Bit error ratio (BER) |
1.00E-12 |
| Data diagnosis-capable (DDM/DOM) |
Yes |
| Power consumption |
≤ 1.5 W |
| Transmitter Optical Parameters |
| Wavelength |
850 nm |
1310 nm |
1550 nm |
1550 nm |
1270 nm TX 1330 nm RX |
1330 nm TX 1270 nm RX |
| Max. transmit power (AVG) |
–1 dBm |
0.5 dBm |
4 dBm |
4 dBm |
0.5 dBm |
0.5 dBm |
| Min. transmit power (AVG) |
–7.3 dBm |
–8.2 dBm |
–4.7 dBm |
0 dBm |
–8.2 dBm |
–8.2 dBm |
| Min. extinction ratio |
≥ 3.0 dB |
≥ 3.5 dB |
≥ 3 dB |
≥ 8.5 dB |
≥ 3.5 dB |
≥ 3.5 dB |
| Receiver Optical Parameters |
| Receive sensitivity (OMA) |
< –11.1 dBm |
< –12.6 dBm |
< –14.1 dBm |
< –24 dBm |
< –14.4 dBm |
< –14.4 dBm |
| Overload optical power (AVG) |
–1 dBm |
0.5 dBm |
–1 dBm |
–7 dBm |
0.5 dBm |
0.5 dBm |
| Operating temperature |
0°C to 70°C (32°F to 158°F) |
–40°C to +85°C (–40°F to +185°F) |
| Operating humidity |
10% RH to 90% RH |
| Storage temperature |
| Storage humidity |
10% RH to 90% RH |
| Dimensions and Weight |
| Dimensions (W x D x H) |
56.5 mm x 13.5 mm x 8.5 mm (2.22 in. x 0.53 in. x 0.33 in.) |
| Weight |
35 g (0.08 lbs.) |
| Model |
XG-SFP-AOC1M |
XG-SFP-AOC3M |
XG-SFP-AOC5M |
| Data rate |
10.3125 Gbps |
| Form factor |
SFP+ |
| Connector type |
SFP+ to SFP+ |
Yes |
| Length |
1 m (3.28 ft.) |
3 m (9.84 ft.) |
5 m (16.40 ft.) |
| Module type |
Active |
| Model |
Description |
| XG-SFP-SR-MM850 |
10G SR module, SFP+ form factor, Duplex LC, 300 m (984.25 ft., with OM3 optical cables) or 400 m (1312.34 ft., with OM4 optical cables) over MMF |
| XG-SFP-LR-SM1310 |
10G LR module, SFP+ form factor, LC, 10 km ((32,808.40 ft.) over SMF |
| XG-SFP-ER-SM1550 |
10G ER module, SFP+ form factor, LC, 40 km (131,233.60 ft.) over SMF |
| XG-SFP-ZR-SM1550 |
10G ZR module, SFP+ form factor, LC, 80 km (262,467.19 ft.) over SMF |
10G LR module, SFP+ form factor, BIDI LC, 10 km (32,808.40.13 ft.) over SMF |
| XG-SFP-AOC1M |
10G SFP+ AOC cable, 1 m (3.28 ft.) |
| XG-SFP-AOC3M |
10G SFP+ AOC cable, 3 m (9.84 ft.) |
| XG-SFP-AOC5M |
10G SFP+ AOC cable, 5 m (16.40 ft.) |
Contacte-nos
