RG-AP840-L Redes de pequenas e médias empresas - 1
RG-AP840-L Redes de pequenas e médias empresas - 2
RG-AP840-L Redes de pequenas e médias empresas - 3
RG-AP840-L Redes de pequenas e médias empresas - 4
RG-AP840-L Redes de pequenas e médias empresas - 5
RG-AP840-L Redes de pequenas e médias empresas - 6
RG-AP840-L Redes de pequenas e médias empresas - 7
RG-AP840-L Redes de pequenas e médias empresas - 8
RG-AP840-L Redes de pequenas e médias empresas - 9
RG-AP840-L Redes de pequenas e médias empresas - 10
RG-AP840-L, Wi-Fi 6 Dual-Radio 5.378 Gbps Indoor AP
Key Specifications
RG-AP840-L
5 Gbps SFP &
RJ45 Combo Port
PoE/DC Power Supply
Ceiling/Wall Mounting
Free Cloud Management
Wi-Fi 6 AX5400
High Concurrency
Low Latency
latency is as low as 20 ms.
High Security
High Speed
With 1024-QAM modulation, the
data transmission rate is 25%
higher than 802.11ac.
160 MHz and 6 Spatial Streams
  • Remote monitoring
  • Remote Wi-Fi management
  • Cloud portal authentication
RG-AP840-L
Unit dimensions(W x D x H)
Main unit: 1.0 kg (2.20 lbs)
13.67 kg (30.14 lbs)
RG-AP840-L
Operating frequencies
802.11b/g/n/ax:
802.11a/n/ac/ax:
Data rates
5 GHz radio:
2.4 GHz radio:
Data rate set
2.4 GHz radio
● 802.11b: 1, 2, 5.5, 11
5 GHz radio
● 802.11ax: 8.6 to 4,804 (MCS0 to MCS11, NSS = 1 to 4, HE20 to HE160)
Packet aggregation
Antenna gain
2.4 GHz: 5 dBi
5 GHz: 6 dBi
Maximum transmit power
Thailand
Vietnam:
5150-5350 MHZ, EIRP ≤ 23 dBm
5470-5725 MHz, EIRP ≤ 30 dBm
5725-5850 MHz, EIRP ≤ 30 dBm
Power increment
Radio technologies
802.11b: BPSK, QPSK, and CCK
Wi-Fi Radio Frequency Performance
RG-AP840-L
MaximumTransmit Power per Transmit Chain
MaximumReceive Sensitivity per Receive Chain
24 dBm
–96 dBm
24 dBm
–95 dBm
–93 dBm
22 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–70 dBm
24 dBm
–90 dBm
–62 dBm
24 dBm
–88 dBm
24 dBm
21 dBm
–74 dBm
24 dBm
–90 dBm
–68 dBm
24 dBm
–88 dBm
–68 dBm
24 dBm
–90 dBm
–68 dBm
24 dBm
–88 dBm
–63 dBm
24 dBm
24 dBm
–90 dBm
24 dBm
–86 dBm
–56 dBm
24 dBm
–83 dBm
24 dBm
5 GHz, 802.11ax (HE160)
–81 dBm
–51 dBm
Bluetooth Radio
RG-AP840-L
Bluetooth 5.1
Maximum antenna gain
10 dBm (Class 1)
Receive sensitivity
–98 dBm
Ports Specifications
RG-AP840-L
● Auto MDI/MDIX crossover
● 802.3az EEE
1 x 10/100/1000BASE-T port
● 802.3az EEE
USB 3.0 (Type-A connector)
RG-AP840-L
PoE port
When powered by 802.3bt (PoE++), the LAN 2 port can source 48 V/12.95 W power to a unit.
USB port
Overall power consumption
● DC powered: 40 W
● Idle mode: 10.3 W
RG-AP840-L
RG-AP840-L
Security standards
EN 62368-1
Cyber security standards
EN 18031-1
EN 18031-2
EMC standards
EN 301 489-3
EN 301 489-17
Radio frequency standards
EN 300 328
EN IEC 62311
FCC Part 15
Applicable Software Version
RG-AP840-L
RGOS11.9(6)W3B3 or higher
RG-AP840-L
150
1024
 Note
Maximumnumber of BSSIDs
Wireless roaming
Layer 2 and Layer 3 roaming
RG-AP840-L
Dynamic ACL assignment
Routing and Switching
RG-AP840-L
IP service
NAT, FTP ALG, DNS ALG
IPv6 basics
IPv6 DHCP Client
RG-AP840-L
Fault inspection and alarm
NTP Server and NTP Client
Ruijie Cloud
Web-based management (Eweb)
Console, Telnet, SSH, SNMP, and TFTP-based management
Fat/Fit/Cloud mode switchover
RG-AP840-L
Up to six spatial streams
Data rate of up to 5.378 Gbps
Fat/Fit/cloud mode switchover
Contacte-nos
Contacte-nos
Contacte-nos
Contacte-nos
