RG-S5750-24SFP4XS24DP-UP สวิตช์ - 1
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 2
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 3
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 4
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 5
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 6
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 7
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 8
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 9
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 10
RG-S5750-24SFP4XS24DP-UP สวิตช์ - 11
RG-S5750-24SFP4XS24DP-UP, 24-Port Gigabit All-Optical Ethernet PoF Switch, 10GE Uplink, Hybrid Cable Connection, Up to 100 W Power Output per Port
Applied in Ruijie Networks Power over Fiber (PoF) Solution, integrated installation and O&M for power and optical transmission over hybrid cables
  • Hybrid cable connection in Ruijie Networks PoF Solution, providing worry-free remote power supply
  • Virtual Switching Unit (VSU), delivering flexible networking and high performance
  • Hardware-level redundancy, enhancing system reliability
  • Multiple security policies to prevent network attacks and ensure high network robustness
  • INC controller, offering simplified and efficient O&M
24-Port Aggregation All-Optical Ethernet PoF Switch on Building Side RG-S5750-24SFP4XS24DP-UP
The switch supports up to 24 hybrid cables, each capable of supplying up to 100 W of power and transmitting optical signals to connected devices. This integrates power and optical transmission and simplifies installation and O&M.
Connection over Hybrid Cables in PoF Solution and Centralized Deployment, Enabling Worry-free Remote Power Supply
The switch utilizes a hybrid cable that implements both high-bandwidth data transmission and remote PoF power supply, realizing integrated installation and O&M, and simplifying all-optical network deployment.
Extended Transmission Range
The connection distance between a PoF switch and an SOE indoor switch can reach up to 1,500 meters.
Increased Power Capacity
A single port can deliver a maximum power of 100 W, while the entire switch supports a maximum power supply of 2400 W (24 x 100 W).
Enhanced Power Supply
The switch can connect 24 SOE switches or photoelectric access points (APs).
Hybrid cables are used to provide secure power supplies from the equipment room, eliminating the need for local high-voltage power sources.
A VSU connects to peripheral devices through aggregate links. If a fault occurs, data can be switched to another link within seconds, ensuring service continuity.
Devices can be added to or removed from a VSU, without affecting normal operation of other devices.
Hardware- and Software-level Redundancy, Enhancing System Reliability
Dual-boot Redundancy
Two flash chips are used to store boot software, enabling automatic backup of the boot file and operating system. This prevents device startup failure caused by flash chip malfunction, ensuring smooth services.
1+N Power Supply Redundancy
A maximum of three power modules can be configured, supporting redundancy and hot swapping and ensuring continuous system power supply.
Fast onboarding
Optical Link O&M
24 x 1000M SFP ports, 4 x 1G/10G SFP+ ports, and 24 x power output ports
128 Gbps
96 Mps
Power module slot
3
Power module type
Available model: RG-PA600I-P-F
Rated voltage range: 200 V AC to 240 V AC
Maximum voltage range: 176 V AC to 264 V AC
Frequency: 50 Hz to 60 Hz
Rated current per input: 8 A
Available model: RG-PA1000I-P-F
SFP port
1000Base-X
100Base-X
SFP+ port
10GBase-R
1000Base-X
RTC
< 85 W
0°C to 45°C (32°F to 113°F) at the altitude of 0 m to 1,800 m (0 ft. to 5905.51 ft.)
At the altitude ranging from 1800 m (5905.51 ft.) to 5000 m (16404.20 ft.), the temperature decreases by 1°C (1.8°F) each time the altitude increases by 220 m (721.79 ft.).
10% to 90% RH
Operating altitude
0 m to 5000 m (0 ft. to 16404.20 ft.)
5% to 95% RH
Fan speed regulating and fault alarms
Temperature alarms
EMI
GB/T9254.1-2021 Class A
Safety standard
GB4943-2011
Weight (including power modules)
10 kg (22.05 lbs)
802.1Q VLAN
4K 802.1Q VLAN
Port-based VLAN
MAC address-based VLAN
QinQ
Basic QinQ
Global ACL
Traffic identification on an interface
Rate limiting on an interface
Eight queues on each interface
SP, WRR, SP+WRR, and RED/WRED
Mirroring
RSPAN
Local and remote flow-based mirroring
DHCP
DHCPv6 snooping
DHCPv6 client
DHCPv6 relay
Binding of IPv4 addresses, MAC addresses, and interface numbers
Binding of IPv6 addresses, MAC addresses, and interface numbers
Filtering unauthorized MAC addresses
Interface- and MAC address-based 802.1X authentication
MAB
Portal and Portal 2.0 authentication
ARP rate limiting
RADIUS and TACAS+
SSH and SSHv2.0
Ring network protocol
ERPS (G.8032), compatibility with third-party ERPS-capable products
Automatic and energy-efficient power supply management modes
Warm start
Scheduled power-on and power-off of PoE ports based on the time range
RIP, RIPng, OSPFv2, OSPFv3, BGP, and IS-IS
Routing Policy
Basic IPv6 protocols
IPv6 addressing, ND, ICMPv6, IPv6 ping, IPv6 tracert, and IPv6 multicast
Defense against NS/NA/RS/RA packet attacks
Preventing private IPv6 address allocation
Unauthorized terminal information buffering
Local and remote stacking
Link bundling across the chassis inside the VSU
Zero Touch Provisioning (ZTP)
CWMP (TR069)
SNMPv1/v2c/v3, CLI (Telnet/console), RMON (1, 2, 3, 9), SSH, Syslog, NTP/SNTP, web, debugging, FTP, TFTP, sFlow, and Ruijie Cloud
Chassis, Power Module, and Accessories
RG-S5750-24 SFP4XS24DP-UP
Aggregation all-optical switch (PoF switch) for buildings, 24-port fixed all-optical switch
24 x downlink combo ports (1GE SFP port and DB78 port)
4 x 1GE/10GE uplink SFP+ ports with auto-negotiation
24 power outputs over hybrid cables, with a maximum of 100 W per output, and up to 2,400 W per device
Up to three power modules
RG-24DUP1DB48LC
Hybrid cable termination box, 24 power outputs per panel, configured based on the number of hybrid cables
OEHC-0.5-1000M
Hybrid cable, cross sectional area of 0.5 mm2, each bundle of 1,000 m (3,280.84 ft.), configured according to the solution
OEHC-1.5-1000M
Hybrid cable, cross sectional area of 1.5 mm2, each bundle of 1,000 m (3,280.84 ft.), configured according to the solution
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
ติดต่อเรา
