Designed for the aggregation layer of large-sized networks, core layer of small and medium-sized networks, and data center server access, this switch delivers high performance, comprehensive end-to-end quality of service (QoS), and flexible security configurations to fully meet the needs of high-speed, secure, and intelligent enterprise networks.
| Port Specifications |
RG-S6160-28VS8CQ-X |
RG-S6160-48VS8CQ-X |
RG-S6160-48XMG4VS2CQ-UP-X |
| Fixed service port |
24 x 1G/2.5G/10G/25G (25G supported by the license) SFP28 ports 4 x 25G SFP28 ports 8 x 40G/100G QSFP28 ports (Each 40G port can be split into four 10G ports or each 100G port can be split into four 25G ports.) |
48 x 1G/2.5G/10G/25G (25G supported by the license) SFP28 ports 8 x 40G/100G QSFP28 ports (Each 40G port can be split into four 10G ports or each 100G port can be split into four 25G ports.) |
48 x 100M/1G/2.5G/5GE/10G RJ45 ports with auto-negotiation 4 x 10G/25G SFP28 ports 2 x 40G/100G QSFP28 ports |
| Module slot |
4 x fan module slots 2 x power module slots |
3 x fan module slots 2 x power module slots |
| Power module |
RG-PA550I II-F |
RG-PA550I II-F |
RG-PA600I-P-F RG-PA1000I-P-F |
| Fixed management port |
1 x MGMT port 1 x console port |
| USB port |
1 x USB 2.0 port |
| System Specifications |
| Switching capacity |
3 Tbps |
4 Tbps |
1.56 Tbps |
| Packet forwarding rate |
915 Mpps |
915 Mpps |
915 Mpps |
| Power Supply and Consumption |
| Power input |
RG-PA550I II-F (AC input): ● Rated input voltage: 100 V AC to 240 V AC ● Maximum input voltage: 90 V AC to 264 V AC ● Frequency: 50 Hz/60 Hz G-PA550I II-F (HVDC input): ● Rated input voltage: 240 V DC ● Maximum input voltage: 192 V DC to 288 V DC |
RG-PA600I-P-F (AC input): ● Rated input voltage: 100 V AC to 240 V AC ● Maximum input voltage: 90 V AC to 264 V AC ● Frequency: 50 Hz/60 Hz ● Rated current per circuit: 8 A RG-PA1000I-P-F (AC input): ● Rated input voltage: 100 V AC to 240 V AC ● Maximum input voltage: 90 V AC to 264 V AC ● Frequency: 50 Hz/60 Hz ● Rated current per circuit: 8 A |
| PoE |
Not supported |
Not supported |
Ports 1 to 48 support PoE/PoE+ power supply. Ports 1 to 24 support PoE++ power supply. Maximum output power of a port: 90 W |
| Maximum Power Consumption |
270 W |
300 W |
Without PoE load: 280 W Full PoE load: 1,480 W |
| Dimensions and Weight |
442 mm x 387 mm x 44 mm (17.40 in. x 15.24 in. x 1.73 in.) |
442 mm x 420 mm x 44 mm (17.40 in. x 16.54 in. x 1.73 in.) |
| Fan module |
Fan module redundancy, hot swapping, fan speed adjustment, and fan fault alarms |
| Temperature alarm |
Supported |
| Temperature |
Operating temperature: 0°C to 45°C (32°F to 113°F) Storage temperature: --40°C to +70°C (--40°F to +158°F) |
| Humidity |
| Feature |
RG-S6160-X Series |
| VLAN |
4K 802.1Q VLANs Port-based VLAN Private VLAN Voice VLAN GVRP |
| QinQ |
Basic QinQ Selective QinQ |
| Link aggregation |
LACP (802.3ad) |
| Spanning tree protocols |
STP, RSTP, and MSTP |
| DHCP |
DHCP server DHCP client DHCP snooping DHCP relay agent IPv6 DHCP server IPv6 DHCP snooping IPv6 DHCP client IPv6 DHCP relay |
| Basic IPv6 protocols |
IPv6 addressing, Neighbor Discovery (ND), ICMPv6, Stateless Auto Configuration, and Path MTU Discovery |
| IP routing |
Static routing RIP and RIPng OSPFv2, OSPFv3, IS-ISv4, and IS-ISv6 BGP4 and BGP4+ Equal-Cost Multi-Path (ECMP) Packet-based and flow-based load balancing MCE |
| Multicast |
IGMPv1/v2/v3 and IGMP proxy IGMPv1/v2/v3 snooping IGMP filtering and IGMP fast leave PIM-DM, PIM-SM, and PIM-SSM MLD snooping and MLD PIM for IPv6 |
| MPLS |
MPLS L3VPN |
| VXLAN |
VXLAN Layer 2 bridge VXLAN Layer 3 gateway Ethernet Virtual Private Network (EVPN) VXLAN |
| ACL&QoS |
Flexible and diversified hardware ACLs: Standard IP ACLs (hardware ACLs based on IP addresses) Extended IP ACLs (hardware ACLs based on IP addresses or TCP/UDP port numbers) Extended MAC ACLs (hardware ACLs based on source MAC addresses, destination MAC addresses, and optional Ethernet type) Time range-based ACLs Expert-level ACLs (hardware ACLs based on flexible combinations of the VLAN ID, Ethernet type, MAC address, IP address, TCP/UDP port number, protocol type, and time range) ACL 80 IPv6 ACL Port traffic identification Port traffic rate limiting 802.1p/DSCP/ToS traffic classification Eight queues on each port Queue scheduling: Strict Priority (SP), Deficit Round Robin (DRR), SP+DRR, and Random Early Detection (RED)/Weighted Random Early Detection (WRED) |
| Security |
3-tuple binding (IP address, MAC address, and port) 3-tuple binding (IPv6 address, MAC address, and port) Filtering of invalid MAC addresses Port- and MAC address-based 802.1x authentication MAB Portal and Portal 2.0 authentication ARP check DAI ARP packet rate limiting Gateway ARP spoofing prevention Broadcast storm suppression Hierarchical management of administrators and password protection RADIUS and TACACS+ authentication AAA for device login management SSH BPDU guard IP source guard CPP and NFPP Port protection |
| Management features |
SNMP, CLI (Telnet/console), RMON, SSH, syslog, NTP/SNTP, SNMP over IPv6, IPv6 MIB support for SNMP, SSHv6, Telnetv6, FTP/TFTP v6, DNSv6, NTP for v6, Traceroute v6 sFlow, which utilizes the random sampling technology to sample flow information of traffic on a switch Management via the public cloud platform and RG-UNC |
| High reliability |
VSU (virtualizing multiple devices into one device) GR for RIP, OSPF, BGP, and other routing protocols BFD ERPS (G.8032) REUP RLDP 1+1 power redundancy Hot swapping of power modules |
| Zero-touch provisioning (ZTP) |
CWMP (TR-069) |
Before ordering a power module or optical transceiver, contact the online customer service personnel for the latest support information about it.
Main Unit
| Model |
Description |
24 x 1G/2.5G/10G SFP28 ports (default rate of 10 Gbps, which can be upgraded to 25 Gbps through licensing), 4 x 25G SFP28 ports, 8 x 40G/100G QSFP28 ports (a 40G port can be split into four 10G ports or a 100G port can be split into four 25G ports), 4 x fan module slots, and 2 x power module slots, with at least one RG-PA550I II-F power module required |
48 x 1G/2.5G/10G/25G SFP28 ports (default rate of 10 Gbps, which can be upgraded to 25 Gbps through licensing), 8 x 40G/100G QSFP28 ports, 4 x fan module slots, and 2 x power module slots, with at least one RG-PA550I II-F power module required |
48 x 100M/1G/2.5G/5G/10G RJ45 ports with auto-negotiation, 4 x 10G/25G SFP28 ports, 2 x 40G/100G QSFP28 ports, 3 x fan module slots, and 2 x power module slots, with at least one RG-PA600I-P-F or RG-PA1000I-P-F power module required |
Power Module
| Model |
Description |
| RG-PA550I II-F |
550 W AC power module |
| RG-PA600I-P-F |
600 W AC power module |
| RG-PA1000I-P-F |
1,000 W AC power module |
| \*RG-PA2200I-P-F |
2,200 W AC power module |
Models marked with asterisks (*) in the ordering information will be available in the future.
Fan Module
| Model |
Description |
| M2SFAN II-F |
Fan module |
License
| Model |
Description |
| RG-24VS-LIC |
License for 25GE ports 1--24, one license per device, which is applicable to the RG-S6160-28VS8CQ-X and RG-S6150-24VS8CQ-X |
| RG-48VS-LIC |
License for 25GE ports 1--48, one license per device, which is applicable to the RG-S6160-48VS8CQ-X and RG-S6150-48VS8CQ-X |
Optical Transceivers
1GE Optical Transceivers
| Model |
Description |
| Mini-GBIC-GT |
1000BASE-X to 1000BASE-T, copper SFP transceiver, RJ45, 100 m over Cat 5e/6/6a The port needs to be configured with auto-negotiation. |
2.5GE Optical Transceivers
| Model |
Description |
10GE Optical Transceivers
| Model |
Description |
| XG-SFP-SR-MM850 |
10GBASE-SR, SFP+ transceiver, 850 nm, Duplex LC, 300 m over MMF |
| XG-SFP-LR-SM1310 |
10GBASE-LR, SFP+ transceiver, 1310 nm, Duplex LC, 10 km over SMF |
| XG-SFP-ER-SM1550 |
10GBASE-ER, SFP+ transceiver, 1550 nm, Duplex LC, 40 km over SMF |
| XG-SFP-AOC1M |
| XG-SFP-AOC3M |
| XG-SFP-AOC5M |
25GE Optical Transceivers
| Model |
Description |
| VG-SFP-SR-MM850 |
25GBASE-SR, SFP28 transceiver, 850 nm, Duplex LC, 100 m over OM4 MMF, 70 m over OM3 MMF |
| VG-SFP-LR-SM1310 |
25GBASE-LR, SFP28 transceiver, 1310 nm, Duplex LC, 10 km over SMF |
| VG-SFP-AOC7M(M) |
25GBASE, SFP28 active optical cable (AOC), 7 m, including one cable and two optical transceivers |
40GE Optical Transceivers
| Model |
Description |
| 40G-QSFP-SR-MM850 |
40GBASE-SR, QSFP+ transceiver, 850 nm, MPO 1 x 12, 150 m over OM4 MMF, 100 m over OM3 MMF |
| 40G-QSFP-LR4-SM1310 |
40GBASE-LR4, QSFP+ transceiver, 1310 nm, Duplex LC, 10 km over SMF |
| 40G-AOC-5M |
40GBASE, QSFP+ active optical cable (AOC), 5 m, including one cable and two optical transceivers |
| 40G-AOC-10M |
40GBASE, QSFP+ active optical cable (AOC), 10 m, including one cable and two optical transceivers |
100GE Optical Transceivers
| Model |
Description |
| 100G-QSFP-SR-MM850 |
100GBASE-SR, QSFP28 transceiver, 850 nm, MPO 1 x 12, 100 m over OM4 MMF, 70 m over OM3 MMF |
| 100G-QSFP-LR4-SM1310 |
100GBASE-LR4, QSFP28 transceiver, 1310 nm, Duplex LC, 10 km over SMF |
| 100G-AOC-1M |
100GBASE, QSFP28 active optical cable (AOC), 1 m, including one cable and two optical transceivers |
| 100G-AOC-5M |
100GBASE, QSFP28 active optical cable (AOC), 5 m, including one cable and two optical transceivers |
| 100G-AOC-10M |
100GBASE, QSFP28 active optical cable (AOC), 10 m, including one cable and two optical transceivers |
