RG-RSR830, 10-Port Mobile Router
The router integrates routing, switching, wireless, and other network functions,
applicable to customers with multiple branches, such as retail stores, chain stores, logistics, and offices.
WAN: 2 x GE electrical ports LAN: 8 x GE electrical ports (LAN/WAN switchable)
RG-RSR830WWAN: 2 x GE electrical ports LAN: 8 x GE electrical ports (LAN/WAN switchable) Wi-Fi 6
RG-RSR830-PWAN: 2 x GE electrical ports LAN: 8 x GE electrical ports (LAN/WAN switchable) PoE
RG-RSR830W-PWAN: 2 x electrical ports LAN: 8 x GE electrical ports (LAN/WAN switchable) PoE Wi-Fi 6
| Hardware Specifications |
RG-RSR830 |
RG-RSR830W |
RG-RSR830-P |
RG-RSR830W-P |
| Forwarding performance |
0.5 Mpps |
0.5 Mpps |
0.5 Mpps |
0.5 Mpps |
| Fixed service port |
Uplink WAN ports: 2 x 10/100/1000BASE-T ports Downlink LAN ports: 8 x 10/100/1000BASE-T ports, which can be switched to WAN ports
Uplink WAN ports: 2 x 10/100/1000BASE-T ports Downlink LAN ports: 8 x 10/100/1000BASE-T ports, which can be switched to WAN ports |
Uplink WAN ports: 2 x 10/100/1000BASE-T ports Downlink LAN ports: 8 x 10/100/1000BASE-T ports, which can be switched to WAN ports LAN ports 2 to 9 support PoE/PoE+ |
| Fixed management port |
1 x RJ45 console port |
| USB |
1 x USB 2.0 port, for connecting to the USB flash drive |
| Memory |
2 GB |
2 GB |
2 GB |
2 GB |
| Flash Memory |
4 GB |
4 GB |
4 GB |
4 GB |
| VPN performance (256- bit AES encryption) |
400 Mbps |
400 Mbps |
400 Mbps |
400 Mbps |
| Number of IPsec VPN Tunnels |
100 |
100 |
100 |
100 |
| Expansion Module |
● SIC-LTE-GS LTE card (Cat-6, 2 x SIM, active-standby) ● SIC-LTE-GD LTE card (Cat-6, 2 x SIM, active-active) ● SIC-5G-G 5G NR in global bands single card, small plug-in card ● SIC-2SFP Expansion gigabit optical module plug-in card |
| Wi-Fi Port |
N/A |
802.11 b/g/n/ac/ax |
N/A |
| Unit Dimensions (W x D x H) |
260 mm × 170 mm × 38 mm (10.24 in. x 6.70 in. x 1.50 in.) |
Without external antennas: 278 mm x 171 mm x 38 mm (10.94 in. x 6.73 in. x 1.50 in.) With external antennas: 350 mm x 171 mm x 88 mm (13.78 in. x 6.73 in. x 3.46 in.) |
Without external antennas: 278 mm x 171 mm x 38 mm (10.94 in. X 6.73 in. X 1.50 in.) With external antennas: 350 mm x 171 mm x 88 mm (13.78 in. x 6.73 in. x 3.46 in.) |
| Unit weight |
0.95 kg (2.09 lbs) |
1.04 kg (2.29 lbs) |
1.05 kg (2.31 lbs) |
1.14 kg (2.51 lbs) |
| Maximum Power Consumption |
36 W (including module power) |
150 W (including PoE power and module power) |
| Input power supply |
36 W Power Adapter: ● Input: 100 V AC to 240 V AC, 50 Hz to 60 Hz, 0.9 A max. ● Output: 12 V DC, 3 A max, 36 W |
150 W Power Adapter: ● Input: 100 V AC to 240 V AC, 50 Hz to 60 Hz, 2 A max. ● Output: 56 V DC, 2.68 A, 150 W |
| Recommended number of user |
300 |
300 |
300 |
300 |
| External Power Supply |
N/A |
N/A |
Each port provides up to 30 W of power. The device provides up to 110 W of power. |
| Temperature |
Operating temperature: 0°C to 45°C (32°F to 113°F) Storage temperature: –40°C to +70°C (–40°F to +158°F) |
| Humidity |
| Altitude |
Operating altitude: –500 m to +4000 m (–1640.42 ft. to +13123.36 ft.) Storage altitude: –500 m to +5000 m (–1640.42 ft. to +16404.20 ft.) |
| IP rating |
IP30 |
IP30 |
IP30 |
IP30 |
| Software Specifications |
RG- RSR830 Series
| Ethernet |
Jumbo frame forwarding (max. size: 1974) Frame format: Ethernet II Change of the MTUs (link MTU and IP MTU) in the forwarding plane Forcibly converting the 1000M optical port into the electrical port in auto-negotiation mode (100M/1000M) LAN/WAN switching Interface auto-negotiation factor Interface WAN/LAN mode switching |
| ACL and QoS |
IP standard ACL IP extended ACL Association with the egress ACL based on a Layer 3 interface (SVI/routed port/L3 AP) HQoS: DSCP/IP-PRE/COS HQoS: PQ\WFQ\LPQ methods of congestion scheduling |
| IPv4 application protocol features |
DHCP client Option 43/52/138 |
| DHCP server Option 138 Option 43 Option 82 Large address pool Alarm (Syslog) |
| Configuring DHCP snooping in a VLAN Configuring DHCP snooping on a logical interface (including the physical interface and aggregate interface) Trusted interface |
| DNS DNS client |
| PPPoE client |
| FTP client |
| NTP client NTP server TFTP client TFTP server |
| IPv6 application protocol features |
DHCPv6 client Option 18 Option 37 |
| DHCPv6 server Option 52 DHCPv6 Snooping ND Snooping |
| FTP server TFTP server TFTP client NTP server NTP client |
| Layer 2 features |
LLDP |
| MAC address filter Interface-based MAC address learning Static MAC address Global MAC address learning Enforcing deletion of a MAC address using a command MAC address aging time Port based VLAN 802.1QVLANTagging PPTP/L2TP Spanning Tree Protocol |
| Layer 3 features |
Proxy ARP ARP entry aging |
| Ping Traceroute |
| GRE tunnel PBR/ACL/QoS/NAT for IPv4 & IPv6 services on a GRE interface Inner and outer VRF configuration |
| IPv4 & IPv6 VRF |
| Static IP IS-IS v4/v6 OSPF v2/v3 RIP v1/v2 PBR |
| NAT features |
NAT sessions:75000 |
| VAG |
Intelligent routing Load balancing Active/Standby scheduling for undefined applications Controller management Disaster recovery |
| WLAN features |
WLAN services: SSID configuration SSID-based VLAN configuration UTF8 SSID |
| Wireless security: WPA3 User isolation: Layer 2 isolation |
| RF resources: Channel configuration Channel width configuration Power configuration Automatic RF optimization (channel, channel width) WMM configuration 802.11 b/g/n/ac/ax |
| WLAN details: |
| Security features |
AAA and web authentication |
| EXEC authorization, RADIUS, interworking with the SAM/SMP/ACS server, and specifying the source IP address (through the source interface) |
| Account allocation by user and login authentication (password, none) |
| Encrypted transmission and storage of static passwords, password lifetime check, and reuse limitation |
| Application identification,url Filtering, IDS/IPS, blacklist and whitelist |
| IPSecVPN function(AES-128, AES-256) |
| CPP and NFPP |
| VPN features |
PPTP,IPSEC,L2TP,L2TP over IPSEC |
| Management features |
gRPC framework |
| NETCONF |
| TACACS |
| SNMP v1/v2/v3 |
| SSH |
| Syslog |
| IPv4 supported by the Telnet server |
| HTTP server V1.1 HTTPS server Out-of-the-box web management |
| Eweb 2.0 |
| Hostname configuration YANG model |
| USB-based deployment |
| Obtaining device information through gRPC |
| Model |
Description |
| RG-RSR830 |
2x GE WAN ports, 8 x GE RJ45 LAN ports |
| RG-RSR830W |
2x GE WAN ports, 8 x GE RJ45 LAN ports, supporting 802.11 b/g/n/ac/ax WIFI |
RG-RSR830-P |
2x GE WAN ports, 8 x GE RJ45 LAN ports, supporting PoE power supply, and maximum PoE output power of 110 W |
RG-RSR830W-P |
2x GE WAN ports, 8 x GE RJ45 LAN ports, supporting 802.11 b/g/n/ac/ax WIFI, supporting PoE power supply, and maximum PoE output power of 110 W |
Expansion Module
| Model |
Description |
| SIC-5G-G |
5G NR small-sized card, supporting dual SIM single standby, 4 x SMA-K antenna interfaces |
| SIC-LTE-GD |
4G LTE small-sized card, supporting dual SIM dual standby and global D band (double) |
| SIC-LTE-GS |
4G LTE small-sized card, supporting dual SIM single standby and global S band (single) |
| SIC-2SFP |
GE expansion card of optical modules, 2 x 1GE SFP ports |
