RG-RSR77-XA-08 라우터 - 1
RG-RSR77-XA-08 라우터 - 2
RG-RSR77-XA-08 라우터 - 3
RG-RSR77-XA-08 라우터 - 4
RG-RSR77-XA-08 라우터 - 5
RG-RSR77-XA-08 라우터 - 6
RG-RSR77-XA-08 10 RU 멀티 서비스 코어 모듈형 라우터
  • A modular design with various expansion card interfaces, supporting rates ranging from 2 Mbps to 100 Gbps
  • Support for Segment Routing over IPv6 (SRv6), simplifying protocol configuration and facilitating quick service rollout
  • Redundancy for critical components, ensuring uninterrupted services and improving overall reliability
  • Y-shaped airflow design, improving cooling efficiency and lowering energy consumption
Multiservice Core Router RG-RSR77-XA-08
Appearance
SRv6
1:1 Routing Engine Redundancy
If the active routing engine fails, data is switched to the standby routing engine within seconds.
3+1 Switching Fabric Module Redundancy
The router supports redundant and hot-swappable switch fabric modules, ensuring zero packet loss during failover scenarios.
RG-RSR77-XA-03
RG-RSR77-XA-08
Module management port
RSR77-XA-03-CM:
● 1 x RJ45 console port
RSR77-XA-08-CM:
2 x supervisor module slots
4 x power module slots
1 x fan module slot
Supervisor module redundancy
Switch fabric module
1.2 Tbps
3.2 Tbps
72 Mpps
192 Mpps
40,000 (Modular port adapter)
2,600,000
2,600,000
2,048
2,048
1,000,000
1,000,000
Number of IGMP Groups
Number of MLD Groups
32,000
32,000
5 RU
10 RU
12.5 kg (27.56 lbs)
43.55 kg (96.01 lbs)
RG-PA460-RI (AC input):
● Maximum input current: 6 A
RG-PA1600I (AC Input):
● Max. input current: 16 A
RG-PD600I (DC Input):
● Max. input current: 20 A
Power output
● Output voltage: 12 V
RG-PA1600I:
● 90V to 176V AC Input:
 ○ Output Voltage: 12 V DC
● 176V to 290V AC Input:
RG-PD600I:
● DC Input:
 ○ Output voltage: 12 V DC
RG-PA460-RI:
● 90 V AC to 290 V AC:460W
RG-PA1600I:
90 V AC to 176 V AC, 1200 W
176 V to 290 V AC, 1600 W
RG-PD600I: 600 W
Supervisor module:
● RSR77-XA-03-CM: < 50 W
Line card:
○ NM-4XS-KB: < 14 W
○ NM-2XS-KA: < 11 W
○ NM-8GT-G: < 7 W
○ NM-8SFP-G: < 16 W
○ DNM-1CQ-KC: < 21 W
Fan module:
● FAN: < 216 W
Supervisor module:
● RSR77-XA-08-CM: < 70 W
Switch fabric module:
● RSR77-XA-08-DSF: < 87 W
● RSR77-XA-08-DSF II: < 160 W
Line card:
○ NM-4XS-KB: < 14 W
○ NM-2XS-KA: < 11 W
○ NM-8GT-G: < 7 W
○ NM-8SFP-G: < 16 W
Fan module:
M10C-FAN: < 216 W
216,000 hours (24 years)
342,000 hours (39 years)
Maximum noise: < 77 dB
35°C (95°F): 60 dB
50°C (122°F): 75 dB
RG-RSR77-XA Series
FTP, TFTP, FTPv6, and TFTPv6
NTP, SNTP, and NTPv6
NAT
ND
ND and ND snooping
IPv6 GRE tunnel
BGP and BGP4+
Routing policies
BGP4, BGP4+, and MP-BGP
IGMP v1/v2/v3
Static multicast routing
MPLS/SR
Basic MPLS functions
MPLS forwarding
L3VPN
LSP
LDP
IPv6 ACLs
Applying ACLs to interfaces
MPLS QoS
HQoS
Attack defense
Password security
RNFP
FPM
PKI
IPsec VPN(AES-128, AES-256)
VPDN
NSR
Hot swapping
SPAN and ERSPAN
IPFIX
RG-RSR77-XA-03
RG-RSR77-XA-03 chassis
RG-RSR77-XA-08
RG-RSR77-XA-08 chassis
RSR77-XA-03-CM
RSR77-XA-08-CM
RG-RSR77-XA-08 routing module
RSR77-XA-08-DSF
RSR77-XA-08-DSF II
Power Modules
RG-PA1600I
RG-PA460-RI
RG-PD600I
Modular Line Cards
RSR77-XA-SIP3
Modular Port Adapters
NM-2XS-KA
NM-4XS-KB
NM-8SFP-G
NM-8GT-G
DNM-1CQ-KC
