RG-S7620-20SFG2CQ Switch - 1
RG-S7620-20SFG2CQ Switch - 2
RG-S7620-20SFG2CQ Switch - 3
RG-S7620-20SFG2CQ Switch - 4
RG-S7620-20SFG2CQ Switch - 5
RG-S7620-20SFG2CQ Switch - 6
RG-S7620-20SFG2CQ Switch - 7
RG-S7620-20SFG2CQ Switch - 8
RG-S7620-20SFG2CQ Switch - 9
RG-S7620-20SFG2CQ Switch - 10
RG-S7620-20SFG2CQ Switch - 11
Seri
and High Performance
Hot-swappable Redundant Power
Hot-swappable Redundant Fan
Quick onboarding
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Module service port
M7600-4GT4VS:
● 4 x 10/100/1000BASE-T ports
● 4 x 1GE/10GE/25GE SFP28 ports
M7600-2CQ:
● 2 x 40GE/100GE QSFP28 ports
4 x fan module slots
M7600-2CQ
M7600-4GT4VS
RG-PA550I II-F
S7610-FAN I-F
S7620-FAN I-F
System specifications
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Packet forwarding rate *1
714 Mpps
1786 Mpps
833 Mpps
2976 Mpps
960 Gbps
2.4 Tbps
1.12 Tbps
4 Tbps
8 GB
4 GB DDR4
36 MB
128,000
96,000
350,000 (shared with IPv6 routing)
4000
65,000
Ingress: 28,000
Egress: 4,000
*1 means the system's packet forwarding rate. For the latest parameters, visit the Ruijie official website.
*2 means the system's switching capacity. For the latest parameters, visit the Ruijie official website.
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
RG-PA550I II-F (AC input):
RG-PA550I II-F: 550 W
270 W
450 W
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
9.73 kg (21.45 lbs)
14.4 kg (31.75 lbs)
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
Front-to-back airflow
27°C (80.6°F): 56 dB
45°C (113°F): 72 dB
3+1 redundancy, and at least three fan modules required
Fan failure alarm
Power port: 6 kV
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
IEC 62368-1: 2018
EN 62368-1: 2014+A11:2017
EN 55032:2015+A1:2020
EN IEC 61000-3-2:2019+A1:2021
EN 55035:2017+A11:2020
EN 300386 V2.2.1
Ordering Information
Device Model
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
IP service
Static ARP
DHCPv6 server, DHCPv6 client, DHCPv6 relay, and DHCPv6 snooping
GRE tunnel
Graceful restart (GR)
IPv4 IS-IS
IPv6 IS-IS
IPv4/IPv6 VRF
IPv4/IPv6 PBR
PIM-SM
PIM-DM
MLDv1 and MLDv2
MLD snooping
MPLS MIB (RFC 1273, RFC 4265, and RFC 4382) (MPLS MIB, MPLS L3VPN STD MIB, MPLS LSR STD MIB, and MPLS VPN MIB)
Expert-level ACLs (hardware ACLs based on the source and destination IP addresses and ports, and protocol type)
ACL 80
Port-based rate limiting
RADIUS authentication and authorization
IEEE 802.1X authentication, MAC address bypass (MAB) authentication, and interface-based and MAC address-based 802.1X authentication
Loose and strict RPF
uRPF ignoring default routes
Device Virtualization
RSPAN and ERSPAN
FTP and S TFTP
VLAN access to VXLAN
IPv4 over IPv4
Distributed gateway
IPv6 over IPv4
VXLAN EVPN
VXLAN static route
Anycast gateway
VXLAN bridging mode
VXLAN routing mode
Static VXLAN tunnel creation
Sumber daya
Informasi Pesanan
RG-S7610-10SFG2CQ
RG-S7610-10SFX2CQ
RG-S7620-20SFG2CQ
RG-S7620-20SFX2CQ
M7600-2CQ
M7600-4GT4VS
Expansion module, 4 x 10/100/1000BASE-T ports, 4 x 1GE/10GE/25GE SFP28 ports.
  • 10 x SFX ports and 20 x SFX portssupport SFG-LR-SM and SFX-LR-SM.
RG-PA550I II-F
550 W AC power module, supporting redundancy, 10 A power cord
1GE Optical Transceiver
10GE Optical Transceiver
25GE Optical Transceiver
VG-SFP-AOC5M
40GE Optical Transceiver
100GE Optical Transceiver
SFM-LR-SM
Tanya-Jawab
